NVIDIA RTX 50 SERIES - (PRE)ORDER DISCUSSION **NO COMPETITOR HINTING**
The Palit cooling is just very meh for an AIB card. According to a review yesterday runs 1c hotter than the FE on the GPU core when noise normalised, which is not good at all.
Are the others £400+ better though?
I will be undervolting mine when I get anyways.
See you in 2070 when the next drop happens :D
There are drops almost every day, the problem is who drops them.
I put the main 10-ish suppliers into three groups, based on price. There's four in the 'trash' tier (incl ocuk), two in the 'ok' tier , and four in the 'near msrp' tier.
There were plenty of drops in trash tier this week, they stay in stock for more than 5 seconds as well. The better priced places sell out instantly, have bots/autobuyers, etc.
It does seem like production has increased, so should only be a matter of time...
5090FE just got dispatched, hopefully won't arrive tomorrow morning when Mrs is home.
Only PC advise...
Keep the same case, so then you can change as many components as you like and Mrs is none the wiser.
Change the case and your in trouble - "Have you got a new PC?" - "How much did that cost?"
You forgot ... stash away the boxes or as a wise man taught me at work.... Get the kit delivered to your workplace
My watch comes to an end with 5090FE on its way. If intercepted, I’ll try to wriggle out by pointing to the fans and say its to cool the CPU.
Finally! Got a Gaming Trio for a "reasonable" price, delivery Wednesday.
