- 6 Jun 2018
Got my 5090FE and coil whine is terrible.
Easily audible when playing most games.
Have a brand new 5090 FE which i've noticed no coil whine with - was nervous given some of the videos i'd seen.
Yeah, put the 5090 Astral in tonight, looks great, goes really well with my case colour, thought perfect. Like the Amps software which was all perfect...run 3d mark for a quick look from stock and...whats that noise I thought...crap, havent heard coil whine in years...A couple more data points:
ASUS ROG Astral 5090 OC: Horrible coil whine. The worst I have ever heard. Even with the case fully closed up and a desk fan going I could hear it. The rear 4th fan was also both loud and has an unpleasant pitch, so needs a fan curve applied. Those points aside this is a really nice card. Seriously good build quality and temps were great - high 60s. Amazing cooling performance considering it would happily chomp through a little over 600 watts. I think a copy with less coil whine and a good fan curve would be top tier (and I realise it's priced accordingly).
Zotac 5090 AMP Extreme Infinity: Moderate to severe coil whine. The whine was a little better than my TUF 4090, but still worse than I would like. Probably at a level someone could live with though. However the main issues with this model are not coil whine but fan noise and the cooling performance. The Zotac is a big card and quite thick, but is still noticeably smaller than the Astral or Aorus (both of which are absolute breeze blocks). It's somewhere between those two massive models and the thinner cards like the Trio and Ventus. The three fans it has that are noticeably smaller and significantly noisier than the Astral or Aorus - more like the 5080 Ventus and worse than the 5080 Trio. I read the reviews where it noted that the Zotac seems to perform like an FE model notwithstanding being significantly bulkier. I've never used a 5090 FE, but honestly if it's as loud as the Zotac I'd probably steer clear. The Zotac felt like it needed circa 2,000 RPMs to keep the card somewhat cool - the Astral could do the same job at much lower RPMs and getting temps down much better. I don't really get why the Zotac is underperforming - on paper it seems better than this, which is a shame as this was the card I really wanted.
I've got coil whine on mine, but it's only at fully maxed out GPU usage/clocks/voltage and really need to focus on it to hear it, but tbh, it's been like that since I got it, I reckon with Asus, you just gotta accept it's gonna have some coil whine, if it really affects you I'd return it and see if you can grab a Gigabyte Aorus or try you luck in the lottery for another AstralYeah, put the 5090 Astral in tonight, looks great, goes really well with my case colour, thought perfect. Like the Amps software which was all perfect...run 3d mark for a quick look from stock and...whats that noise I thought...crap, havent heard coil whine in years...
Returning a Palit, all boxed, but no coil whine I could hear. Got 3O days with OC, does coil whine settle? Or just ur luck?
Really like this card as well...
What to do...
So does that mean you got both a Palit and an Astral, and the Palit has no coil whine while the Astral has a lot?Yeah, put the 5090 Astral in tonight, looks great, goes really well with my case colour, thought perfect. Like the Amps software which was all perfect...run 3d mark for a quick look from stock and...whats that noise I thought...crap, havent heard coil whine in years...
What to do...
Palit had none (575 W) may matter? Astral has some but I didnt notice it whilst gaming, just on benchmarking on 3d mark. But really like the Astral, quality, looks great, runs great, OC is great, quiet enough with fan tweak, so will see how I get on over the next wee while. Still have an open order with the rain forrest on a Suprim LC. If that had actualy been shipped last week, i wouldnt have bought Astral, but still glad I did now.So does that mean you got both a Palit and an Astral, and the Palit has no coil whine while the Astral has a lot?
5090 solid - coil whine running 3dmark in my first test - so i think it will go back.
Yes I recently purchased one. My impression of the coil whine is that it's decently low. Tested in Doom Eternal: more or less inaudible at 120fps. Slightly noticable at 240fps and then more so at 400fps. But even during the notorious Witcher 3 menu at 1200 fps: while noticeable it's still relatively OKish. I would say definitely lower coil whine than my previous 3080 SuprimX which was already decently quiet. I would be surprised if there were any 5080s that would have significantly less coil whine as this card. Even at 400fps sound of the fan @ 1400rpm is louder than the whine, although the whine and the fan noise can be clearly distinguished one from another.Dear Overclockers, I am wondering about the Inno3D 5080 x3 /OC Cards. Any experiences with those cards regarding coil whine or bad temps/fan noise?
Best regards
Robin
I can't work out what 'beeps and rattles' areI returned the Zotac 5080 Solid OC and got a Zotac 5080 AMP. Both have the exact same coil whine. I've returned that one too.
When you hear it with the case closed, it's unacceptable to me.
I'll wait for an Aorus Master. There's stock right now, but it's very inflated, almost €1,800.
If you're interested, I found a German forum that also covers this topic, including user experiences. It's easy to read with Google Translate.
[Sammelthread] - Blackwell RTX 5xxx: Coilwhine / Fiep / Rassel Thread - Here we go again
Here we go again: Neue Generation - neue Runde.: Ada Lovelace RTX 4xxx: Coilwhine / Fiep / Rassel Thread 99 Likes & < 689.000 Views. :bigok: @English readers If you are looking for information on a specific GPU, you will find the post number in the “Beitrag” column, which contains more...www.hardwareluxx.de
Youre right - my 4090 had no coil whine - then i tried the same speedmark benchmark last week prior to ordering the new card and i could hear it whining a bit in that test .I think if your criteria is that there should be no discernible coil whine even under completely uncapped scenarios (i.e benchmarks) then you're probably in for a bad time. Personally, I'm only really concerned about high-load 120fps performance as that's what I will experience semi-regularly and that's what I test to for coil whine when I get a new card. Also, consider adding a global frame cap to prevent things like title screens hitting 600fps and whining like crazy. I use a 120Hz 4K screen and don't play any super-competitive insanely high FPS games so I can get by with a ~150fps global cap.
