- 18 May 2010
- London
arrived, quick service
i'm going to browse like i've never browsed before![]()
What sort of performance improvement are you seeing in the browser?
You don't need to reinstall windows you just need to reactivate it following the detected hardware change.having done a CPU swap myself, I can say its buggered my windows license and I now show as you need to register windows.
while I only game so its minimal annoyance I need to reinstall windows now and go through the setup, I have tried to rectify but nothing has worked so far.
I feel like a plonker right now.You don't need to reinstall windows you just need to reactivate it following the detected hardware change.
Thinking of getting the 9800 my first amd cpu.
recommendations for a mobo? I like the look of the TUF board.
Is game mode still needed or even beneficial on this CPU? I know you need this on the dual CCD chips but does it have any benefit on the 9800x3d?
Also what power plan is recommended?
That’s good to know.Pretty sure game mode for the 9800x3d is a no. It's for the chips like the 9900x3d and 9950x3d.
I use the windows balanced power plan.
Thought it might improve fps in games maybe?
Its in the normal range yeahWell the CPU is in!
Currently idling at around 45C in desktop, that sound ok?
You planning an all core or per core?Just playing DayZ max 61C average 54C. Happy with that!
Now to OC PBO haha
Good luck![]()
SP rating does not matter too much. Don’t worry about it. Some very good chips are 111 for example and some very bad ones are 120.hah All core
Notice the SPD is showing 114 not sure if that relates to others
