- 28 Mar 2006
Just had my Fibre internet installed and sadly had to get the router moved to a room at other end of the house. We live in a Semi Det 1950s house (think brick internal walls and solid concrete floors!) and have found the Wi-Fi strength in our office is a tad weak (-70dbm give or take).
I'm using a powerline adapter which is ok (ish) but does sometimes drop to 40mbps speed when I should be getting 100+ from the fibre.
Ideally looking for a solution that will work for me without having to spend £££ on Ethernet in the house (which will be a pain due to brick walls and concrete flooring) - we have the most up to date Sky Hub router (not max) but will swap this out for something which works better and meets needs.
Any recommendations?
