- 4 Jul 2006
Nice, im currently on 366.3 / 321 for March so far.I’ve already smashed my monthly target, I’m on 619, the target was 580ish I think.
My target for March was 763kWh, I'm now on 800kWh with a week to go. Based on the average for the month so far I am still (just!) on track to hit 1MWh but the weather forecast for the week is looking pretty miserable. I think realistically I'm going to end up somewhere above 900kWh but below the 1MWh mark.
I did some rough calculations. Should be able to fit 40 or so panels on my house and outbuildings.
Is there a limit on how many Kilowatts a house can have?
1MWh in March sounds awesome![]()
There's no limit to how many panels you can have but there likely will be a limit placed on you by your DNO. 40 panels will be in the 18kWp sort of ballpark and unless you're the only house for miles around your DNO is very likely to cap you on export. I am export limited to 5kW for example. You'll then want big batteries to store your generation and export it over time according to whatever your limit is which will drive up your system cost quite a bit.
Best taking this conversation to the other thread to keep this one about production figures as intended![]()
