I assumed that was the case with mine but i reseated it and its lovely now. if anything the magnets are a little bit too powerful.Neither is mine? Its a rubbish after thought!
Also delete your steam shader cache. It will all be Nvidia and will mess up your AMD performance SteamLibrary/steamapps/shadercacheits arrived so i guess that means im actually in the club now
first time ive ever changed a gpu let alone swapping teams so gotta do the ddu thing put te gpu into the pc and then install stuff will report back later
That's a low 5070Ti score to be fair though. I'm in the top 100 for my XT score but only in the top 14% of 5070Ti's and I get 7900, 79fps with a game stable configuration.Who needs a 5070 Ti?
Average looks to be about 6300ish but my card ain't even the XT, it's a humble 9070 lolThat's a low 5070Ti score to be fair though. I'm in the top 100 for my XT score but only in the top 14% of 5070Ti's and I get 7900, 79fps with a game stable configuration.
You are correct, i'm thinking of my RT Port Royal score against the 5070Ti. No 5070Tis beat my Steel Nomad score as the top 5070 Ti score is 7800. My 21000 score in Port Royal can't match the top 5070Ti's though, pretty sure i'm in the top 14% of 5070 Tis.Average looks to be about 6300ish but my card ain't even the XT, it's a humble 9070 lol
9070 already does more than I need it to do to be honest, I'm good with that.You are correct, i'm thinking of my RT Port Royal score against the 5070Ti. No 5070Tis beat my Steel Nomad score as the top 5070 Ti score is 7800. My 21000 score in Port Royal can't match the top 5070Ti's though, pretty sure i'm in the top 14% of 5070 Tis.
You're 25% behind an XT clocked similarly, that's not a small gap.
Yeah it's a cracking card, I wasn't saying otherwise. Probably the best value to performance ratio card you can buy right now.9070 already does more than I need it to do to be honest, I'm good with that.
I'm getting like 7300-7400 on my xtThat's a low 5070Ti score to be fair though. I'm in the top 100 for my XT score but only in the top 14% of 5070Ti's and I get 7900, 79fps with a game stable configuration.
I was just under 7150 out of the box. Just under 7900 is with an undervolt, vram overclock and 10% power increase. I made a separate post detailing all the tweaks and gained a bit extra with a custom fan ramp, since that post.I'm getting like 7300-7400 on my xt
who did you buy it from? OcUKMine is with Royal Mail on it's way back with powercolors blessing for odd harmonics and bearing noises on the card. Hopefully I get the replacement soon...
I've got a new case coming with a bit more room from OCUK coming tomorrow, partly all this tearing down and such has made me want to have easier access again.
Yes i did.who did you buy it from? OcUK
CPU cooler? How is that not sitting flush. Please do elaborate....Nor is the CPU cooler
Lets put it down to optical anomalies
It would probably be a bit cheeky to ask if I could put a bit more towards a higher model now i've got a case with more spacewho did you buy it from? OcUK
I don't know...Reaper cooler awfully thin for a 300++ W card...It would probably be a bit cheeky to ask if I could put a bit more towards a higher model now i've got a case with more spaceto be fair the reaper was really not bad at all, if it did not have that odd fan sound it's solid.
