What happens when Zen 6 arrives and if they increase the fabric speed to 6400/6800/7000mhz etc.. wont they make these cl26 kits now abit outdated?
I guess a cl26 kit would proberly do 6400mhz @ cl26 though.
thats how it goes with RAM
What's more likely is they'll just rebadge them and give them a new profile, because they're binned better than most 7000-8000+ kits that already exist.What happens when Zen 6 arrives and if they increase the fabric speed to 6400/6800/7000mhz etc.. wont they make these cl26 kits now abit outdated?
This is indeed just how this industry works. You can buy something day 1 and it will be outdated in 6-12 months as the refresh or new generation comes along.Yes, of course, that's how IT innovations work. Old tech becomes obsolete not matter how good it is.
I'm sure that DDR5 will be obsolete with Zen 5 million and so don't buy a kit and hold out for then and only buy DDR8x, not DDR8 because 8x will be better.
sooooooooooo speculative.
EXPO timings below if anyone feels like trying on their DR kits.
74.1 ns on Expo but I've got a lot of crap installed and background processes running.Whats your latency on these? On Aida64 latency tester mine runs around 66ns which i find abit hight tbh compared to my old intel setup which was sub 50ns.
Do you mean x870e? I have the Asrock x870e tachi lite and with all the 9800x3d chips dying I feel lucky to be at expo on my gskill cl 30 64Gb kit. I think its more common on the x870e nova motherboard though.So i have the CL28 and CL26 kits as samples and my Gigabyte X870I board couldn't run either of these. Switched to the Asus X870i board and bam it runs both flawlessly. The CL28 kit can be pushed too!
Did manual tweaking help on the Gigabyte board ?So i have the CL28 and CL26 kits as samples and my Gigabyte X870I board couldn't run either of these. Switched to the Asus X870i board and bam it runs both flawlessly. The CL28 kit can be pushed too!
Could you link Buildzoid’s timings by any chance? I’m waiting for OCUK to get the CL26 kit in and hopefully this will bring a little more performance from stock.Unfortunately not, manual tweaking made it worse if anything. OCCT would error out after 10 seconds.
I've banged Buildzoids timings into the CL28 kit with some adjustments for testing and it's passed OCCT 1 memory hour test.
Thank you. I don’t have as much time to tinker these days.
Im running exactly this with my Hynix A Die Acer Predator (BIWIN) CL30 6000Mhz kit - Currently tuned to CL28 6000Mhz with a nice bump in performance and it feels nicer.
Also using ASRock X870 Nova Board and trying not to adjust anything CPU (9950X3d) side for a while until I know its stable.
