Internet browser keeps crashing
18 Nov 2010
I only ever have internet browser/spotify and Football Manager running on my computer, but for some reason my intenet browser keeps crashing, ive even tried different browsers, chrome/edge/firefox/brave etc, still keeps happening, any ideas?
Does it just close itself with no error window or message or something? What are the specific symptoms? Is it immediate or when you go to a particular site?
As asked above, what do you mean by "crashing"? Assuming you aren't running out of memory, it sounds like you have a software problem, or a hidden instability issue.
He said it.happrns on all different types of browser so dont think it woulf be a plugin. Maybe you should just reinstall windows
Without knowing his hardware I'm not sure if that's really going to help.
While he states that he games, after looking up the system requirements of the latest Football Manager it would run on a toaster and a wet fart. A lot of modern browsers run on Chromium, which is notoriously hard on RAM, and even those that don't can be on the hefty side. If the OP is running a laptop with 8gb of memory, and a chunk of that partitioned to the IGPU, or even just an older RAM limited desktop, he could very well be running into RAM related problems, which given his explanation doesn't sound improbable to me. Hell, even 16gb of RAM could cut it close depending on usage these days, you have enough tabs running and you'll have issues sooner or later.
