This needs to die - Nvidia drivers in 2025 are a joke.it's not like green team plug n play
Meanwhile, the only problem I've had with my 9070xt is the BIOS/splash screen not appearing over HDMI. But this seems display-specific.
sorry I did not get notificationHi mate.
Happy with you new gpu?
What sort of temps,gpu clocks are you getting? Is it quiet, fan speed?
I think about buing one.
Thanks
When you set pl +15% how far will core boost?sorry I did not get notification
I run it mem 2700
-100 mv
and power limit -15
Power around 260W and core in games 3080-3100 and I would say it is silent
Core temps about below 65 - ram 79-82
-15%plWhen you set pl +15% how far will core boost?
My non XT Pulse Vram rarely hits low 80's which is of no concern.Im debating getting a 9070 non-xt before the prices go up because of the tariffs but I see that there's a lot of talk about the 9070 series having high VRAM temp's. Do you think any of the cards will be viable in a low airflow enviroment ( Fractal Design R6 ) ?
Hi guys,
Main issue is I get random black screening when I reboot my PC, it's like the PC is failing to post. It's a white line (like a MS-DOS style cursor) on a black screen. If I button the PC it goes straight off, and if I turn it straight on it does it again but this time after a few seconds proceeds to BIOS splash screen and Windows boots up normally. Once I'm in Windows it's solid. No driver issues, great performance, no crashes. Used it since Thursday like this and it's been great apart from when I need to reboot for a driver or Windows update.
I've updated my BIOS and disabled auto-GPU detection for onboard iGPU (although I don't have one on my 5900x) and also forced the PCIe and Chipset into Gen4 from auto after I read about issues with Auto defaulting to Gen 5 which I don't have. List of specs below. Any advice appreciated, I really, REALLY don't want to return the card but if I can't have a reliable boot.. then guess there's no choice for me.
Pretty sure its on UEFI but good shout.Double check you've disabled Legacy Boot or CSM Boot in the bios, I had weird posting issues with my 9070 before I did that.
Make sure FastBoot is disabled tooPretty sure its on UEFI but good shout.
Any owners of Pulse 9070XTs- does it have Honeywell PTM or is it thermal paste?
Also if PTM how long does it usually last before needing a reapplication?
Amazing. Good to know this. Presumably the fans will fail before a reapplication is needed then! Thanks.Don’t own it myself, but it’s PTM
PTM virtually never needs to be redone. It lasts years/decades.
but one thing I've noticed with AMD over the yrs it's not like green team plug n play
I think the most interesting thing about that is the apparent transient power spike to 360w, with the card otherwise running at ~252w the rest of the time. If that's not a glitch in the monitoring, I wonder if it could be the cause of the instablility a couple of people have mentioned? If a non-XT at 250w is spiking to 360, is an XT at 340w spiking to 450w? Could be enough to upset a borderline PSU...
Other than that, I conclude that Superposition is slightly harder on memory than anything else, and even in that 'worst' case memory TJunc stabilises at ~86c. Which I suppose is on the warm side, but seems in line with what others are seeing, and is easily far enough away from TJMax that I'm fine with it; and comfortable enough not to start pulling the card apart looking for improvements.
Honeywell. All 3 of the Sapphire cards have it.Any owners of Pulse 9070XTs- does it have Honeywell PTM or is it thermal paste?
Yeah just checked. Boot is UEFI not CSM and I have no option to enable or disable fast boot in UEFI, it's only an option if I switch to CSM. Still stumped. It's still doing it. I guess I'm going to have to return the card which massively sucks.Make sure FastBoot is disabled too
