- 7 Jan 2009
Hey,
I'm not too familiar with Macs, However I've got an older Macbook Pro (A1278) That the Hard drive died and is no longer been detected OR spinning up.
I've swapped out the HDD for an SSD, Downloaded OSX Catalina and got Belena etcher to burn a bootable DMG..
However this doesn't seem to be working, I'm holding down the "alt" key to select the usb drive but no usb drive or the ssd is showing.
however it does show "EFI boot" but when i click on that i just get a cross in a circle (which i assume means non bootable)
i don't have another mac to do this, ONLY windows systems. :/
appreciate any help.
cheers
cheers
Although i did install 10.7 Lion as that is what apparently came with the system from the factory, Need to do more research on what is the latest that will work with this machine.
