So, I'm running a Samsung OLED G8 3440x1440 175hz "smart" monitor. Thing is I get dark smearing, sorta like VA trailling, on desktop that is very very noticeable. I can also get the monitor to show an effect like overshoot but that much less noticeable. Now this is not what I pictured owning an OLED would be like
Symptom: drag any window on desktop with darker shades of grey into an area with black and see heavy black trailing in the grey.
My setup on desktop: Black background, hidden taskbar, 1 minute screensaver with a blackscreen. Everything is dark mode themed. Mainly for my eyes sake but also for the monitors.
Monitor is setup to use all its anti burnin features but is otherwise stock in its settings outside of brightness being turned down from 50(max) to 25.
Now to the question: Do OLED pixels need to "warm up" to perform their best? I remember having an IPS a long time ago that didn't perform that great until like 20 minutes after I've turned it on.
If that is the case then I guess I've set the panel up for "failure".
Things I've tried: Using HDMI, using DP, increasing the brightness, resetting the monitor(several times), looking for a inf download on samsungs site(no luck), tried windows, tried linux, tried 60hz, 120hz, 175hz, tried game mode(on monitor) off and on.
.Symptom: drag any window on desktop with darker shades of grey into an area with black and see heavy black trailing in the grey.
