- 25 Aug 2008
- York, UK
I have found over the past few years that whilst the strong UV doesnt cure the blanket weed, it seems to definitely slow mine down, so it is easily controllable.....or is that just a placebo effect on me? lolYou may get green water initially. Tap water has nitrates in it, so it will often cause a bloom with sun due to the nitrates feeding the algae. It can be cleared simply by a chemical additive in the case of a small pond like this but it may come back. A UV clarifier doses the water passing through it with UV light to kill the green small algae (it doesn't stop blanket weed). However a natural pond will eventually reach an equilibrium.
It's worth learning about the nitrogen cycle: https://www.mankysanke.co.uk/html/good_water_guide__pt_15.html this should arm you with understanding about the nitrogen cycle so you can see how this will work with plants. Note that the may need nutrients added periodically if there's no animals in the pond (unlikely!)
Running water is good for a sound effect too in addition to moving the surface of the water to allow oxygenation.
On replacing my UV's I discovered one of the locking nuts has perished (due to the UV weakening it most likely).
Managed to secure it for now (very slight leak, so not put the new UV in yet), ordered some new locking nuts and spares (with new O rings), should arrive Tuesday.
