CPU Upgrade Decision
28 Jun 2005
I'm upgrading my lad's rig which is currently running a GTX 1080 and an i7-7700k, so, really in need of a refresh. He uses it mainly for gaming and school stuff. I've picked up the bits below from MM and elsewhere but I genuinely don't know which way to go with the CPU. I'm wondering if the i5-12600 might be underpowered for running with a 3080 and if I should go with an i5-14600K for £200 for future-proofing purposes? I'd be buying it new from OcUK but the degradation issues has given me pause for thought. Any recommendations would be appreciated. Thanks.
i5-12600 (non-K)
MSI VENTUS 3X RTX 3080
MSI Z690 Edge WiFi DDR4
Team Group 8Pack Ripped Edition DDR4 3600 C14 (4 x 8GB)
Seasonic Focus PX-650 Platinum PSU
Cooler <undecided>
Case <undecided>
If you already own the 12600 I'd just go with that, it is fine for a 3080 and like you said, avoids the potential for 14th gen shenanigans.
There are some circumstances the CPU will hold you back (some games more than others), but it'll get most of the performance so I have no concern in using it.
Thanks for the replies. He's not bothered about RGB and wanted a solid side panel so have gone with an Antec Flux SE (Black/Walnut). Cooler is going to be either a Thermalright Peerless Assassin 120 SE Black Dual Tower CPU Air Cooler or an Arctic Freezer 36. Cheers.
I had a very similar set up to that, same cpu, same motherboard, same memory albeit 2x8Gb and it was a good match for my 7900GRE which is more powerful than a RTX 3080 (I had a RTX 3070 originally). None of it ever struggled with anything I threw at it. I only upgraded because I fancied a upgrade and wasn't going to touch Intel because of the 13th/14th gen issues and high power draw. If you are not having a window just get the cheapest version of the Peerless Assassin (I had one on my 12600) or the Phantom Spirit with the extra heatpipe. There is no point in paying a extra £15 for the black version, it doesn't cool any better and if you have no window you won't see it anyway.
