Caporegime
- 8 Jan 2004
- Rutland
You can but it doesn't convert 1:1.So we can't stack 3 year core membership before converting into ultimate membership anymore?
That means we get same conversion rate whether we do 2 years or 3 years?You can but it doesn't convert 1:1.
Will this work ok for an expired sub and can I get 3 years worth (3×39.99) of core and then convert to ultimate with 1 x £14.99 (using the last method)These are the new prices using cdkeys (only 5 months on!):
Easiest (most expensive price)
Buy via console/ms site: 12x£14.99=£179.88.
Minimal faff (medium price)
cdkeys sell 3 months keys of gamepass ultimate for 29.99 so buying 4 of those and stacking would be £119.96 (monthly price £9.99).
Most faff (cheapest price)
12 months gold/core from cdkeys for £39.99
stack 2 codes for 24 months for £79.98
convert to 12 months of ultimate by paying 1 month £14.99
Total for 12 months ultimate 79.98+14.99=£94.97 (monthly price £7.91).
rp2000
when you say convert to 12 months of ultimate by paying 1 month... do I do that by redeeming another code or by doing it in the xbox profile?
Was that 12 months core on an expired GP sub?I miss the older conversion rates, I got 7 months GPU this time, but for using the 'most faff' method above.
Yeah had just expiredWas that 12 months core on an expired GP sub?
Is EA play when redeemed to xbox region locked or can it be activated using a VPN like you could with GP? I'm currently farming MS Rewards and getting just enough (in NZ) for GPU but would be good to be able to supplement with a 12 month ea play card to give 3 months of GPU for low price if my rewards dont quite cover the price.I saw elsewhere if you get EA 12 months play code which is £19.99 it converts to 4 months Ultimate
Can get 3 for £60 (or less if you have the means) and then upgrade to Ultimate
Seems to be the cheapest way to get a year of GPU
£6.25p/m
or £5p/m best case scenario
I think the £1 is either gone or only for new users.Is this not a thing anymore? When I look at doing the Ultimate upgrade it says £14.99 a month, not £1.
