- 24 Jun 2021
- Oxon
It's their provided router, if it doesn't work it's their problem, wifi is part of the service I'm paying for.I would be amazed if the YouFibre network was congested to the point you were being dragged down to 10Mbps.
If you're trying to terminate the contract due to degradation of service there is no chance they're going to take your Wi-Fi speed tests.
Edit: BQM doesn't work btw, guess it isn't compatible. No data shows up.
Edit2:
Again, wasn't an issue with BT. So if it is a wifi issue it's still a case of switching back to BT. Or I guess getting another router, but that should be at the ISP's expense not mine.Found the issue.![]()
A what now? And why should a customer need to do this? Again, BT didn't have this issue....aside from the speeds randomly dropping to 10Mbps? Have you done a spectral analysis to see what's going on when the issue hits? It could be some kind of interference.
Could in theory try to rule out the wifi, bunch of faff though, maybe at the weekend. Not sure I have all the wired gear anymore either, haven't needed it for years. It's a rummage through the garage storage boxes job.Set up a MySpeed on a local wired machine. Wire up the PC and leave the laptop wireless. When the issue presents on the WiFi device(s), test from the wired PC.
Sure feel like I'm getting blamed for this ISP being trash, but w/e.You can switch back to expensive, asymmetric BT if you like, it's no skin off anyone else's nose.
No I don't have a spare router. Again, wifi is part of the service, and it worked with BT. I don't want to have to be wired, especially for a laptop, which is supposed to be portable lol, the whole point of having a laptop is being able to sit elsewhere in the house rather than being glued to a desk.That said, you're throwing the baby out with the bathwater here. Have you an alternative router to try? Get some cables connected and your problem will likely vanish unless it's a faulty router or ONT (less likely).
