- 5 May 2004
sorry for above post as was using phone , i meant i brought the ryzen 5 7600 and went with the b580 and have been very happy with it
Likely due to the utter dumpster fire of optimisation that is UE5 and Alchemist not liking that engine at all.
I believe that Arc Alchemist does not accelerate through hardware one specific but important function that UE5 requires; Battlemage, however does.
I installed a B570 on a 5600X system today. The results are comically bad in MMOs.
With lot of players on screen the game is capped at 30fps with max settings at 1440p. Dropping to low (potato) settings and 720p increases it to a few frames above 30fps when it should be running hundreds. The CPU bottleneck is real.
Fortunately I knew this was going to happen, so it doesn't matter. But for entry level gamers who don't know this, this is bad.
Fixed issues:
Marvel’s Spider-Man 2* (DX12) may experience an application crash while loading to gameplay.
Cyberpunk 2077* (DX12) may experience an intermittent crash on certain motherboards with Ray-Tracing on.
Known issues:
Intel® Arc™ B-Series Graphics Products:
▪ Call of Duty: Black Ops 6* (DX12) may exhibit flickering corruption in certain scenes during gameplay.
▪ Returnal* (DX12) may experience an application crash during gameplay with Ray-Tracing settings turned on.
▪ Call of Duty: Warzone 2.0* (DX12) may exhibit corruptions on water areas in certain scenarios.
▪ MLPerf may exhibit intermittent errors when running on multi-GPU system configurations. It is recommended to disable integrated
GPU as a workaround.
▪ SPECapc for Maya* 2024 may experience intermittent application freeze during benchmark.
▪ PugetBench for Davinci Resolve Studio* V19 may experience an application crash while running the benchmark.
You've got to think it's actually true given how much damage control is taking place.
I'd really consider one, but I just wish Intel would pull the finger out and release a stronger card, with wider memory bus and even more memory.
Is it too much to ask, for a card to come with large amounts of VRAM and not cost thousands of dollars? :'(
And another driver update 32.0.101.6739
Can i ask if you get any direct x12 issues when gaming with your asrock.i have the asrock b580 steel legend and i have had crashes in cod6 and apex with dx12 errors.Tbh Ive been been doing clean installs with every driver update and all seems ok for me, Ive been swapping out my AcerA770 and my Asrock B580 every few weeks aswell with no issues.
