PC build help. £1,000
22 Jun 2018
Hello im wanting to build a new system for faster performance.
Case - https://www.overclockers.co.uk/msi-mag-forge-112r-mid-tower-gaming-case-black-ca-011-ms.html
PSU - https://www.overclockers.co.uk/cors...power-supply-cp-9020295-uk-pow-crs-03874.html
Motherboard - https://www.overclockers.co.uk/msi-...ocket-am5-ddr5-atx-motherboard-mb-375-ms.html
RAM - https://www.overclockers.co.uk/team...000c38-6000mhz-dual-channel-ki-my-0ay-tg.html
Hardisk - https://www.overclockers.co.uk/wd-b...0-solid-state-drive-wds100t3x0-hd-58f-wd.html
OS - Windows 11 Home - https://www.overclockers.co.uk/microsoft-windows-11-home-64-bit-dvd-oem-kw9-00632-sw-18j-ms.html
GPU - I own a NVIDIA GeForce RTX 2070
Will these parts work together, will all psu wires be long enough and provide power cable to my graphics card, when comes to installing Operating system windows 11 requires Secure Boot, and TPM 2.0, can it all be enabled in the MSI BIOS?
Would the 750 watt power supply be enough for the system and the GPU card I have.
Can someone check all these parts will work together with no issues.
Thanks David.
£60 (incl. VAT)
£55 (incl. VAT)
£115 (incl. VAT)
£90 (incl. VAT)
£160 (incl. VAT)
£155 (incl. VAT)
£120 (incl. VAT)
£108 (incl. VAT)
Just browsing the internet with chrome and firefox. And for pc gaming on steam.
Current system.
AMD Ryzen 5 3600X
16GB DDR4 memory 3200mhz
AM4 GIGABYTE X570 GAMING X
Samsung SSD 860 EVO 500GB (SSD)
650 watt corsair PSU
AM5 motherboards are all Windows 11 compatible.
Yes.
Where is CPU and CPU cooler?
Note that case has a max GPU length of 330mm (important: this is not that long).
Are you factoring selling your existing parts into your budget?
If that's not something you're comfortable doing, you might be better off sticking with AM4 and grabbing a 5700X3D and a faster GPU.
My basket at OcUK:
Total: £986.90 (includes delivery: £7.99)​
Your existing PSU might be reusable depending on the exact model.​
I'd be tempted to go for the 5700X3D + higher end GPU, a 9070/XT with a 5700X3D will outclass a 7000/9000 series CPU + a 2070
Thanks for the reply's
Im going stick with the original parts i've posted , I want the faster 6000mhz DDR5 memory + CPU.
Would this case be better for GPU room? - https://www.overclockers.co.uk/lian-li-lancool-iii-rgb-full-tower-pc-case-white-ca-7az-ll.html
GPU Support420mm
And ill ask again will all parts work?
That's a shocking amount of money to spend on a case when you're working with a limited budget, especially given you desperately need a GPU upgrade given your use case.
Outside of gaming you don't do anything that stresses your hardware, you're very unlikely to notice the difference between your current rig and what you're planning on for web browsing and youtube.
Yes, but Lian Li's 216 would be a better choice for value.
B650 and 7700 is compatible, though the Tomahawk you're looking seems expensive, given that the newer B850 has PCI-E 5.0 graphics (at least, most of them do).
The RAM appears to be XMP (intended for Intel). I don't know if it is present on the motherboard's QVL. However, most 6000 kits will work with Ryzen 7000/9000.
The SSD fits the motherboard, but there have been some issues with WD's DRAMless drives like the SN770 and Windows 24H2. I think it has been resolved with firmware updates, but an alternative drive might be a prudent choice there.
PSU: has the necessary connectors, but seems expensive when the RMe is positioned below the RMx/RMx Shift.
I'd be tempted to go for the 5700X3D + higher end GPU, a 9070XT with a 5700X3D will outclass a 7000/9000 series CPU + a 2070
this.
but as always, your money your problem.
There's something in the water here lately mate I swear.
:cry:
:cry:
Magical.
Ask for advice after purchasing an item they clearly don't understand, then get mad when advised by people that do understand it. Been seeing it a lot lately, I figure there must be a full moon at least somewhere in the universe and I'm pretty sure half of these people aren't from this earth.
The above isn't directed at you OP/Bitfenix, it's just an odd trend.
Regardless, I would really consider why you're upgrading and what you want from it. @Tetras has already suggested better options for the same or similar money if you're dead set on a platform update and keeping your current GPU for the time being.
Just sticking a 5700x3d will be a big upgrade to your system and should eek out more performance on your 2070 depending what you play and at what resolution.
Just decided instead of building a new system, I could upgrade my CPU to this - https://www.overclockers.co.uk/amd-...hz-socket-am4-processor-retail-cp-3cb-am.html
Would I notice a difference?
Thanks.
Technically you'd see some uplift, but for the price difference between it and the 5700X3D you'd be better off going for the 5700X3D as you'll see far better gains in gaming.
It's the L3 cache that helps a lot, the X3D chips have more of it so even though the 5800X (not X3D) has faster clock speeds it'll ultimately be worse.
You'd be much, much better off going for a 5600 (do not get the 5500, it has lower L3 cache than even the standard/non X3D chips) if you're looking for gaming CPU uplift on a tight budget, which should be achievable for around £100, or a lot less if you're willing to go second hand.
