Mini PC's
9 May 2008
Hi.
Really can't make up my mind what I want :-)
I want a PC that will run EA programs, If you don't know what they are they run on MT4 and MT5 and trade the forex markets for you. I currently pay for a vps but I figured why pay £25 a month for that with limited performance when I could run my own from home?
I also have the meta quest 3 512gb headset that i plan to use for VR related games.. I purchased ages ago and it's still boxed.
I am thinking maybe a mini pc might be a good way to go but am not sure. I did purchase one but it was noisy and at the time it would have been in my bedroom. I now have a spare room so could put it in there so noise wouldn't really be a factor. I seem to change my mind all the time so it's about time I actually purchased something permanent.
Any advice would be great and well received.
A micro-atx or itx PC would be more easily upgradeable and could be made into a gaming system for VR, but it would be less portable and (depending on what you buy) more expensive.
If size/space isn't an issue, I'd be inclined to build a (full size) PC instead, but this is a gaming PC forum so obviously I'm biased.
That seems pretty good. I did a search on the card and many reckon to go for the XT ver. What do you think?
Sure, but I'd have a look at this thread, if you plan to use it for VR:
If you plan to use multiple HDMI monitors I'd also check this thread (it might only be relevant to the Sapphire, since most models have 3x DP and 1x HDMI):
