MOT fail thread
As per your recent post about the snapped driveshaft and coil springs you can't always see what is going on internally with metal - it might have been corroding away behind/inside until it finally came apart.
I agree, It 100% was, and that hole wasn't there before I put my finger through it, but it was so obvious (or should be) to any tester the previous year that it was, or was about to be a problem.
Anyway, we all know it wasn't his "mechanic mate".....
Ha, I should imagine you're right!
There's always an excuse.
This is the new knuckle/hub with actual threads that we fitted to hold on the caliper & carrier, not cheap!
And god only knows how this wasn't picked up as an advisory/failure on the previous MOT (different car)..
Quite rare to see a subframe in this condition (that's directly where the steering rack is bolted on to).
It's a Corsa in case anyone was wondering.
One of my MK7 Celicas flew through its MOT and then when I was underneath it a couple of weeks later fitting a new backbox I discovered that the rear subframe had rotted through in a place that effectively meant one of the three points that stops the offside rear wheel assembly falling off wasn't there anymore.
I have had severely reduced faith in the MOT system since then. :p
It’s not the system as such, it’s some of the testers that are the problem.
There’s a great deal of people that shouldn’t be let loose around a car, let alone have the ability to test them.
True in that case for sure, although there are also plenty of ways to fudge a car through an MOT because testers aren't allowed to remove things.
I may or may not have got a MK2 MX5 through one last MOT by covering the rotted through chassis rails with plastic covers many years ago... :o
We’re allowed to remove things as long as tools aren’t required, although that’s changing now for some EV’s ie Merc EQE/EQS where a cover needs removing to access bonnet release, then more to access master cylinder, battery etc.
We’re still not allowed to remove wheel trims though :rolleyes:
They might have been self tappered directly into the rail. :o
Don't worry I'm a new person now, wouldn't do stuff like that. Honest. :D
Theres also the kind of tester I've encountered once or twice who feels the need to add an advisory item for each individual area of the underbody and each individual suspension component which is surface rusted. On a 90's Japanese car...
I mean sure, its a fair cop I suppose, but is it really needed? It makes it look like a right ****ter on the MOT history! :(
No, it’s not needed and is quite ridiculous that some do it.
You only have to look at some of the posts in here and elsewhere in “motors” to see people worried about corrosion advisories that are just surface rust and present no safety issue at all.
Kind of reminds me of this:
The "some components unable to be inspected due to undertray" advisory annoys me too.
It also needs to be taken in context with the model of vehicle - some will get extensive, concerning looking, surface corrosion but will be structurally fine for years and years and years, others like the D40 Navara corrosion is bad news.
The crazy thing is most of the US you don't have anything resembling an MOT and yet Jaywalking is a criminal offence. You can drive any deathtrap you like but get in the way of it without an official crossing, you're booked.
Yep... The Just Rolled In Youtube channel is constantly filled with absolutely insane deathtraps.
But then I just watched a Police chase video from Tampa where one cop rams an assailants car into a civilians car, and then a second cop directly rams the civilians car which then almost crushes two pedestrians, so I don't think you're safe on the roads out there no matter what... :p
