I just found new friends. LolI am in no rush, but most of the people I ride with are now on E-bikes, so I am feeling left out.
I currently ride a Druid, so Druid Core would seem a natural upgrade, but it does look a bit bulky in profile!Druid CorE would get my vote over the Unno - if that Forbidden rides anything like the regular Druid, it will be punching well above its stated weight category and their geo will be very well tailored to the platform.
Unno looks nice (although the carbon layup is not in the same league as something like Hope's HB916, at least from what we've seen thus far) but the lack of cable-routing for a rear mech and the speed sensor being built-in to the rear disc seem like odd choices.
Swapped the 165mm cranks on my Levo for 155mm cranks from Hope. Took a couple mins to get used to, but getting less pedal strikes.Any of you experienced 155mm cranks on your mountain bikes?
That's an E bike though isn't it? Specifically wondering about anyone with a mountain bike, see if they miss the torque.Swapped the 165mm cranks on my Levo for 155mm cranks from Hope. Took a couple mins to get used to, but getting less pedal strikes.
I went 160 from 170 and noticed my gear choice of 6 dropping to 5 on slight inclines. It made the bike feel heavier BUT slightly more agile because there was less striking on roots and rocks. I like it and I dont. On the park bike I have 160 as I dont pedal up hill so if you are lazy like me then go for itThat's an E bike though isn't it? Specifically wondering about anyone with a mountain bike, see if they miss the torque.
That's the thing I do like hills. Going from my current 165mm to 155mm would be paired with also going from a 30t to a 28t.I went 160 from 170 and noticed my gear choice of 6 dropping to 5 on slight inclines. It made the bike feel heavier BUT slightly more agile because there was less striking on roots and rocks. I like it and I dont. On the park bike I have 160 as I dont pedal up hill so if you are lazy like me then go for it![]()
It is and it may sound odd being assisted, but i did notice the drop in torque and I use more of the larger cogs on the cassette now and spin moreThat's an E bike though isn't it? Specifically wondering about anyone with a mountain bike, see if they miss the torque.
Had a bike with 155mm Hope's on as a loaner for a week, couldn't get on with them - felt too 'spinny' for me, but I think that will come down to personal preference and leg length.Any of you experienced 155mm cranks on your mountain bikes?
V1 or V2?I currently ride a Druid, so Druid Core would seem a natural upgrade, but it does look a bit bulky in profile!
V1V1 or V2?
I agree that the packaging around the motor could be a little cleaner and the Mith looks far more svelte in that regard, but I think the downtube is nicely in-line with their other models.
We get you are nursing a semi over the Mith, but you are being somewhat hyperbolic with your statements here.Rob's 'Preview' of the Unno Mith : This thing is just amazing: the visible carbon weave in the frame, the low weight, the high power & torque, the large battery, and the price is not crazy either.
Seems like this is shaking up the eBike market in the same way the iPhone did to the mobile phone sector in 2007.
Check the motor bolts first. Second, check that there isn’t a plastic dirt shield still installed as they can creak and squeal, this sits between the crank and the bearing and is like a packaging item. Lastly, check the bolts in the rear triangle and the shock as they may have worked slightly loose.Went for a play at the local today with a new action cam. Pretty impressed with the footage straight off the camera.
I have a slight clicking noise when I pedal, you can kinda hear it in the video. Think I need to tighten the cranks up or something. Anyone know the torque settings for the gen 5 cube cranks?
