NVIDIA RTX 50 SERIES - (PRE)ORDER DISCUSSION **NO COMPETITOR HINTING**
Wow! Did this happen to your unit? Were you able to replace it under warranty?
I noticed it within a week or two. Took a pic, then took another 2 weeks later and it had clearly moved. It looks like the putty is just wriggling it's way out altogether.
I refuse to be Gigabitten again lol. I just returned it within 28 days as no way I'd get a warranty claim as they are saying there is no issue.
Real shame as the card and cooler were fantastic
I see the barcode place hasn’t had a delivery of Zotac 5090 solid cards since the 28th and even then it wasn’t many.
Have they genuinely done something to annoy Zotac?
I’ve never seen a company ship so little to one place and lots to another, especially when these cards are in stock elsewhere for long periods.
That's unfortunate. Glad you got sorted. I had the Aorus Master and really liked the card. I had it mounted horizontally though and didn't have any issues till I sold it to a relative for cost. He also has it mounted horizontally. I'll let him know not to change to vertical mount since he's past the return window now.
That's good. Tbh it was a pretty good sample so I may just go up to the white Zotac 5090 now in case I got an inferior 5080 :D
4090's still sell for £1,600-£1,700, there's no way I'd take a £400 loss selling to cex.
When you read the horror stories of ebay, it certainly becomes a bit more appealing just to be done with it. There is only so much you can do as the seller to protect yourself. Ebay always sides with the buyer on any issue (even if entirely fictional and you have evidence to disprove it).
Can you recommend any other avenues?
As a former owner of the 5080 Ice as of today, I would strongly advise against if you have any plans to mount vertically. I've sent it back as thermal putty started to seep out after 2 weeks and seems to be widespread across the entire Gigabyte range.
They have tried to say it's no issue but starting to see more severe cases now
Gigabyte released a statement about this along the lines it should be ok and they put too much gel originally on the first batches.
We have hundreds of Zotac in stock now and our price is very good. :)
Check gigabytes sub-reddit. There is a new case where the putty just completely slid out and it ended up frying the card.
Mine was in process of doing same, after 2 weeks. I'm not taking a chance at £1400
3 weeks lol. When I read about the issue I photo''d it. Clearly had movement in the space of a week and was the same location, appearance and shape as all the other cases I've seen
Did you have it mounted vertically?
I’ve had my master 5090 for a month and can’t see anything but will keep an eye on it. Hopefully it would have happened by now if I had a bad batch
Yea it was vertical. I reckon they either used the wrong putty in earlier batches or the 5090 version has slightly different layout and it isn't as easy for it to escape.
Who knows, I had thermal pad issues with my gigabyte 3090 as well so I just not taking the chance with this. Going to avoid Gigabyte now which is a shame as the card was lovely.
