I have the palit gamerock non oc model if I want to do it, was just doing some extra reading about the air and liquid models before deciding what to do next. Suprim soc air is quieter than the liquid in terms of fan rpm on silent bios, as I've already experienced that and it was acceptable fan noise, unfortunately kept black screening during use for me so had to return it.
The Palit fans are annoying if I don't have the rest of my case matching the rpm to drown it out a bit better. my issue having never done it before is making sure I buy all the right parts
 and seems like one of the waterblocks I need is out of stock unless I buy one from China, not sure what the best solution is really.
Maybe I should do the same as you, as I just want peace of mind, of knowing everything I bought will work together.
I did get the Palit at a price however where all the additional costs will end up matching suprim soc near enough if I go in that direction. Perhaps I should make a post, someone did reply to me with their set up, but it was for the ventus, not sure if I could use all the same parts and just switch the waterblock used, guess I'll ask.
