Weird in-game cap
28 Jan 2011
Got the new CPU in yesterday, played 3-4 comps in CS2..I run at medium settings in 4K, and don’t get me wrong, it’s butter smooth, but something strange is happening..
My FPS counter is pegged at 225fps, ok, it drops to 223 / 224 but basically pegged.
The frame limit for in game is 300, and my refresh rate is 240hz? What could be causing this? Like I said, not an issue just can’t figure out the cap at 225?
gsync/adaptive sync is on, and some vsync method that is aware of adaptive sync is keeping fps locked just below refresh rate as recommended
most likely nvidia control panel vsync or its max frame limiter
Ahh, ok , awesome, thank you, good to know. Running smooth so not going to change this.
There may be a degree of rounding error involved as well - often with things which limit the framerate other than V-Sync there is some loss of precision at the sub-millisecond scale.
