Look for some local companies in your area, that people can recommend, iirc a few people round here have systems that suppliers that will cover your area
Get at least 2 to quote, but ideally 3
Do some research before you get them round. You can fairly easily calculate the sort of system your roof can take, ie number of panels
Do you want batteries, if so having an idea of your annual useage helps
Do you have an Ev / heat pump or plan to get either in forseeable future
Does your roof have shading, and which direction does it face
South facing is ideal, if so depending how large your roof is consider north facing panels as well, despite many suppliers saying they dont make sense
Look at the main suppliers and see if there are any things you specifically want.
Most can be more flexible if you want to run home assist, but some are more powerful than others natively. Eg Victron is probably the most powerful but it will take some time investment to get there.
There are some fundamental differences between the hardware suppliers in regards access. Some eg Givenergy are more locked down, which may trigger you some issues later if you want to change stuff.
Others, eg Solax are supposed to be, but the installer password is googleable so you can get round most of the issues in that regard.
There are pros and cons with both those scenarios.
Lastly, off the top of my head, if your getting batteries the place you plan to site them. Some installers will not loft install, some will. There was talk of regs saying they should not be in the house in the UK but that seems to have gone quiet.
Some are more suited to outside than others, (although most do seem to say avoid direct sunlight which installers seem to ignore).
In the UK you may want to get batteries with heating built in, or plan a way to insulate and low level heat them for any prolonged very cold spells.
The winter we just had was warm so no one really had issues, but the one before most people with outside batteries had charging issues at times (which will range from slower charge to refusing to charge depending how cold it gets).
Oh and consider islanding, or ability to go off grid in times of grid downtime. Its in the kind of £600-700 pound region to enable for most that can do it.
There are some more basic ways to do this, but with systems being able to give you whole house Emergency power for that sort of amount it seems hardly worth one of the cheaper dubious ways to do it.
IMO educating yourself a bit before you start speaking to installers makes that far easier. And you far more likely to get a system your happier with longer term.
Bear in mind most installers will have one or two hardware producers they normally use. So if you have hard requirements in regards certain things (like the islanding) you want to know that in advance.
