Max settings with minimal reliance on DLSS, MFG, go for 5090. Anything else, 5080 should suffice. Your budget should be the defining factor.
I still use MFG and DLSS in all games with the 5090 for 4k120
To be fair, you shouldn't need MFG for most games to play at max settings @120fps with a 5090. There are obviously exceptions to the rule.I still use MFG and DLSS in all games with the 5090 for 4k120
I just don't know why I can always tell with the latency. Visually, there's minimal difference thoughMFG X4 with DLAA on Doom for 4K 240, and I wouldn't have a clue it's not native![]()
And the Alphacool block I ordered just shipped!I know! I'm starting to believeOff work next week, so hopefully dispatched next couple of days
May have to send that back now unfortunately. It's a good problem, at least there are blocks available!Indiana Jones on 5090 FE maxed out path tracing 4K still need to use DLSS to be above 60. I use DLSS quality majority of game 70s to 80s frame rate. Sukhothai level when in the outdoor bit it even sometimes goes down to 50s.To be fair, you shouldn't need MFG for most games to play at max settings @120fps with a 5090. There are obviously exceptions to the rule.
Yeah, games like Indiana Jones are the exception. That's why I went with a 5090 instead of a 5080Indiana Jones on 5090 FE maxed out path tracing 4K still need to use DLSS to be above 60. I use DLSS quality majority of game 70s to 80s frame rate. Sukhothai level when in the outdoor bit it even sometimes goes down to 50s.
That’s why i turned off PT and play at a glorious 150+fps. Well, i did before i gave up. Found it very boring versus the former Playstation story games i’ve played recently. They’ve set the bar pretty high for me. But i do have the attention span of a goldfishIndiana Jones on 5090 FE maxed out path tracing 4K still need to use DLSS to be above 60. I use DLSS quality majority of game 70s to 80s frame rate. Sukhothai level when in the outdoor bit it even sometimes goes down to 50s.
To be honest, it’s one of best looking games I’ve played in ages, if ever. But also I went from an IPS 1440p to a QD-OLED 4k as part of my upgrade, that certainly would’ve played a role too.That’s why i turned off PT and play at a glorious 150+fps. Well, i did before i gave up. Found it very boring versus the former Playstation story games i’ve played recently. They’ve set the bar pretty high for me. But i do have the attention span of a goldfish![]()
Like the buses. Can't wait, these next few days are going to drag. I suspect ocd will kick in big tomorrow and ill find myself refreshing my emails a hundred times. That will continue when it is with DHL. My last order from them arrived next day, but i suspect that was luck and would normally be 2. I wonder what the freebie for the delay will be.And the Alphacool block I ordered just shipped!May have to send that back now unfortunately. It's a good problem, at least there are blocks available!
@Gibbo Any Idea when the next stock of Asus 5090 OC Astral are due in? managed to miss the last two stock updates..
Got your tracking info yet? Someone on the subreddit got DHL tracking. I ordered from a UK site though, so not sure how much that will delay my order. The Alphacool block just arrived, shame I might not use that. Does look very nice.Like the buses. Can't wait, these next few days are going to drag. I suspect ocd will kick in big tomorrow and ill find myself refreshing my emails a hundred times. That will continue when it is with DHL. My last order from them arrived next day, but i suspect that was luck and would normally be 2. I wonder what the freebie for the delay will be.
NVIDIA RTX Blackwell architecture, 21760 CUDA cores, 2407MHz Boost clock speed, 32GB GDDR7 VRAM, 512-bit Interface, PCIe 5.0 connectivity
Thanks Gibbo. Please do one for the Astral. I am looking to pick one up if it is in the 2.7k range.Hi there
Special limited deal, Zotac 5090 Solid ONLY £1999, 100 units in stock and 100 more due next week, once these 200 are sold the price goes back up as margin is low on this deal!
SAVE 5%![]()
- SKU: GRA-ZTC-04049
- EAN: 8886307700025
- MPN: ZT-B50900D-10P
Fair do's. I'll keep an eye out!No chance on Astral at moment sorry, maybe in a month.
