 - 18 May 2025
 - Herfordshire
Hi everyone,
I have an ASUS Ryujinn AIO. I replaced the stock fans with iCUE.
The cable from the AIO has been plugged into the AIO pump header on my motherboard (ASUS 870e Hero).
The fan cables go to the iCUE hub.
This leaves my CPU fan header empty, as the fans are controlled by iCUE.
Will I have issues with the BIOS when booting up for the first time (or after).
Will I need to purchase this and connect it from my iCUE hub to the CPU fan header to by pass this?
					www.corsair.com
Any help massively appreciated as this is my first build.
Also noted my Corsair HX1000I PSU didn't come with a 6-pin PCIE cable!
				iCUE LINK System Hub Tach Cable 600mm
This cable is used to connect your System Hub to a CPU_FAN header on your motherboard to allow your system to boot normally.
