I would imagine so.I'll be interested to know if they improve the dac itself or just use the exact same one but slap on more i/o and a better amp
Super Early Bird | Kit
About £321
i5 headphones
13.5mm Standard Cable
13.5mm to 6.35mmAdaptor
14.4mm Upgraded Cable
14.4mm to XLR Adaptor
Extra Earpads
It will have XLR in/out almost certainly for balanced in/out.
I might just decide to back the kickstarter whilst it's still going and then if I don't like them, then sell them after it ends at below normal price but at or above kickstarter price. Seems a win/win situation. But if I do like them, then shift the Arya Stealth, although the reviews I watched from tubers that I resonate with since they have similar tastes say the i5 is Ananda Nano class but better, though perhaps not to the level of an Arya class planar because it doesn't have the super low bass extension.The extra balanced cables and adaptors alone should cost about £30-40 if bought separately, the ear pads easily £20 if they sold that separately. There is also the shipping which is quite reasonable. It's basically only about £250 for the headphones if you break it down.
It does however have a nicer construction, nicer pads, superior cable (upgraded graphene cable) and comes with XLR adapter so yeah, a better package overall for what will be similar money to the Arya Stealth current prices.
Oh yeah massive face size planars are great!
Edit* Didn't realise Zeos had them , he sayd "I think this is better than every HiFiman under $1000" - That's some feat:
@Raymond Lin one you may be interested.
Been watching his reviews for a while, just a chilled out guy who knows his craft.
FiiO will be sending me a K13 R2R once samples are ready. So this is a thing now I guess![]()
