MSRP Vs MSRP that's pretty good for B580 given it's going to be about £100 cheaper. It will be interesting to see if AMD can deliver a 9060 with usable ray tracing hardware given its got the same number of shader cores as the card it's replacing.Rumour: B580 10% slower than Radeon 9060 XT.
AMD Radeon RX 9060 XT appears in first synthetic benchmarks: at least 25% faster than RX 7600 XT - VideoCardz.com
Radeon RX 9060 XT in first tests It appears reviewers already have access to the Radeon RX 9060 XT for testing. The next release from AMD is the Radeon RX 9060 XT, a mid-range Navi 44-based graphics card for desktops. It will come in two variants: one with 16GB of memory and another with 8GB. […]videocardz.com
Note that the B580 figures I used were from Dec 24.
I don't really want to spend that much so the Intel Arc 750 looks to be the bet price would this OK?
Yeah, but if it is worth paying £50 over the A310, I don't know. The IGP in your 9950X3D is based on RDNA2 so the Arc is better (it has AV1 encode, for example).I do a lot of video encoding but never used a GPU to encode (using Staxrip) and the 8gb on this does look better than most low end cards.
Some of the AMD cards look at bit too pricey and I don't really want to spend that much so the Intel Arc 750 looks to be the bet price would this OK? I do a lot of video encoding but never used a GPU to encode (using Staxrip) and the 8gb on this does look better than most low end cards.
It gets a bit more compelling when you throw in the 8Gb 9060 to the mix. Given it's the same die size as the older 7600 AMD could easily drop the price of it to around £220 and put B580 in a difficult position.B580 vs RX 9060 XT 16 GB.
TLDW: The RX 9060XT is about 25% faster. Sometimes more, sometimes less. This puts them on a par value-wise, the 9060 XT being 26% more expensive. Both cards are (as of writing) available from OCUK at MSRP.
The performance is tanking I'm sure is more to do with the 9600K is a 6 core with no hyperthreading rather than the Arc 580.
put an equivalent Nvidia and AMD GPU up on the same CPU for comparison.
