New pc build recommendation
30 May 2025
barnsley
Purchase Timeframe: 1 week
Budget: £500-£700
Usage: every day use gaming playing 1080p. I play on a 240hz monitor
Preferences: ideally wanting to use ryzen 7 and a tower cooler
Current Hardware:
Processor AMD Ryzen 7 3700X 8-Core Processor 3.60 GHz
Installed RAM 16.0 GB
Storage 932 GB HDD ST1000DM003-1ER162, 932 GB SSD WDC WDS100T2B0C-00PXH0
Graphics Card NVIDIA GeForce RTX 4070 Ti SUPER (16 GB)
System Type 64-bit operating system, x64-based processor
Peripherals: none
Special Needs/Requirements: None
I am wanting to upgrade from my current pc but i am wanting to re use my graphics card (4070 Ti SUPER) or do you reccomend upgrading my graphics card aswell?
Slightly over budget, but you could probably re-use your cooler if it can handle a 3700X.
My basket at OcUK:
Total: £722.95 (includes delivery: £7.99)​
No, CPU is the right move for 1080p, unless you're doing path tracing :o
£540 (incl. VAT)
£400 (incl. VAT)
£175 (incl. VAT)
£150 (incl. VAT)
My basket at OcUK:
what would u recommend if i wanted to spend a little less on a processor? or would you not? i will also be needing a psu what would you recommend? thanks
£540 (incl. VAT)
£400 (incl. VAT)
£175 (incl. VAT)
£150 (incl. VAT)
For 1080p, I would not.
If I had to save a bit: the 7800X3D.
If I had to save a lot: 9700X.
If I just wanted a "good enough" upgrade with plans to upgrade again later: 7600X (they're available as low as £150 now).
First one if cost is an issue and the second one if you got the spare money.
The AMP GH is built by Helly who Seasonic use for their lower-end PSUs and the warranty is 8 year (normally would expect 10-year for a gold PSU).
The HCG Pro is derived from Seasonic's Vertex, but has a 10 year warranty instead of 12 year on the Seasonic.
My basket at OcUK:
Total: £252.89 (includes delivery: £7.99)​
Only upgrade when you really have to. But upgrade CPU and memory. DDR memory is pretty cheap also
If you've got money to burn get something else, like better quality keyboard, speakers, joypad, joystick, steering wheel etc.
its going to be a new build. the only thing im keeping is a 4070ti super. ideally id like this new pc to last me a fair few years
