Howdy!
I have an indoor bike. Nothing fancy, the resistance is just a pad on the weighted wheel at the front. The little computer it has just gives me distance, rpm and calories. But I'm in disagreement with it.
I've only just started so I do half an hour and mix it up with fast and slow bits and high and low resistance. Has me knackered lol. In that time I do just 8 miles but I am sweating. The calorie readout says I've only burned like 100 calories and I'm guessing it is just using the little sensor to read the rpm of the wheel and calculating from there. It isn't taking in the resistance or effort I'm putting in.
So my question to fellow cycle people (indoor and out), for those that want to track heart rate, calories, etc, what sort of device can I get myself?
Are there things that perhaps clip to your trainer? As I was looking into all these watches and things but then I thought if my wrists are fixed on the bars, would it work properly and know that I'm doing exercise / cycling?
Any help much appreciated as I would like to know what I am burning.
Cheers folks.
PS. Apologies if there is some sort of mega thread on this that I have missed!
Cheers folks.
