#Try and build your 1st base between griffins reach tradepost and the wreck of the halcyon
#Make sure you check every corner of each NPC base as some intel/skill points are hidden
#Planetologist trainer Derek Chinara moves around at every stage of the quest chain so you will need to find where he is
#Try and build your second base in western vermillius gap - you will be close to the anvil trade post and sheol for duralanium ore which you will need for your first ornithropter
#Hoard water as quickly as you can - processing of resources requires a lot of water!
#Try and do DD runs for MK6 resources out of hours if you are solo - less chance of being blown to bits.
#Always take a blood extractor and blood bags with you - you turn blood into water and can drink blood if you run out of water
#Always take Literjons out with you to collect dew at night so you can top up your tanks in the early stages of the game
#Don't underestimate how quick the worm is and how close it can breach to you
#When you move from hagga basin south into the vermillius gap, there are some paths through the dunes that are quicker and easier than others.
