New to building PC - can someone cast an eye?
4 Jun 2025
ENGLAND
Hi all, just looking for some help with my build - this will be my first PC (my XPS has finally died and am finally pulling the trigger on a PC). Would really appreciate someone casting an eye on the parts I’ve picked.
If I’ve not been clear enough please let me know!
Purchase Timeframe: 1-2 weeks is fine
Budget: £1700-2000
Usage: Gaming - would like to be able to do 4k with some games, at a good frame rate. Also do quite a lot of photoshop. Other than that, the usual office type stuff.
Preferences: not really, just the best hardware I can get for price that will last several years. Don’t want an ugly machine, but don’t care about a light show
Current Hardware: A Dell XPS 9570 that has been used into the ground
Peripherals: I have a 4k monitor and keyboard/mouse
Special Needs/Requirements: none
Currently I’ve looked on overclockers and settled on this, but being a bit of a noob, would appreciate some learned people having a ganders - really open to tweaks.
  • 1x Fractal Design North Charcoal Black
    TG Dark Windowed Mid Tower Case - Black
  • 1x Intel Core i5-14600K (Raptor Lake-S)
    Socket LGA1700 Processor - Retail
  • 1x MSI MAG Z790 TOMAHAWK WIFI (LGA 1700) DDR5 ATX Motherboard
  • 1x TeamGroup Delta RGB 32GB
  • (2X16GB) DDR5 PC5-48000C38
    6000MHz Dual Channel Ki
  • 1x be quiet Light Loop 240 ARGB White High Performance CPU Water Cooler -
    240mm
  • 1x Sapphire Radeon RX 7900 XT Gaming
    20GB GDDR6 PCI-Express Graphics
    Card
  • 1x Seasonic VERTEX GX-850 850W 80+
    Gold Modular Power Supply
  • 1x WD Black SN7100 1TB SSD NVME
    M.2 2280 PCle 4.0 Solid State Drive
Total: £1,896.05
Thanks guys!
Some of your component choices are out of date or needlessly expensive for what they are, that's a last gen AMD GPU and Intel CPU. Intel's Raptor Lake have problems with degradation over time also, I'd be loathe to recommend one in a new build. I assume you're planning to build this yourself, or are you looking at prebuilds?
Upper end of your budget:
My basket at OcUK:
Total: £2,049.86 (includes delivery: £11.98)​
For gaming at 4K it'll be superior to what you were looking at by a fair margin, you could save money on the CPU by going for a £220 9600 or a higher core count chip like the 9900 assuming Photoshop can make use of it (I've no idea on that front). Higher resolutions tend to favour the GPU more, but there are still some games which heavily favour the extra L3 cache provided by X3D processors even at 4k.
The GPU selected should fit in that case, it might be a little tight.
yeah go for something like that, or replace GPU with 9070XT
Is that case glass fronted, I could see airflow being restricted as it has to be drawn through front side vents not directly.
I actually thought I'd specified the mesh version so good catch.
Hard to beat for £50, comes with a boatload of fans and excellent airflow but there are some downsides, the review is worth a watch.
Just be aware of depth of case also, might not fit the biggest GPU's
Probably worth it to bigger case, buy once and if it's a few inches deeper and wider you won't regret it later
I'd look into what's the biggest GPU now, see if that fits so you have peace of mind now...even if you aren't going to buy a breezeblock sized GPU. Also same for air cooler HSF, also checkout rad. I'd probably want 420 for future rad expansion for example.
£100 (incl. VAT)
£98 (incl. VAT)
MATX variation with a 360mm AIO + "fishtank" style case to display all the rgb bling-bling goodness
Change back to the Peerless Assassin 120 if you want to save an extra £20
PSU and case currently out of stock unfortunately - could drop OCUK a call to find out when they will come back in stock
My basket at OcUK:
Total: £1,975.84 (includes delivery: £0.00)​
My basket at OcUK:
Thanks again - just a quick q; do you have any other recommendations for PSU and case? Seems like they’re going to be out of stock for a while…
I’m not too bothered about RGB, and would probably prefer something less loud and more sleek if possible.
challenge accepted :)
do note that because it is a smaller case, will need a bit of thought and finesse to build. but very smart once all assembled
the psu will need to be mounted in the F2.5 or F3 location
My basket at OcUK:
Total: £164.94 (includes delivery: £0.00)​
I don't think that case comes with any fans, it's probably worth adding at least a couple of Arctic P12's or something.
the 360mm aio will provide 3 fans as exhaust up top :P
if really wanted, then a couple of slim fans below the gpu to make a bottom-to-top airflow pattern (which incidentally, is how my fan config is set up too :cry: )
Think that’s the plan!
Thanks again
just for clarity this is the updated build list:
My basket at OcUK:
Total: £1,983.82 (includes delivery: £0.00)​
swapped to cheaper RAM - same timings so no performance loss, just cheaper
motherboard is OOS at OUCK but available elsewhere (and i can see that they're cheaper than ocuk too) - when you buy this elsewhere just make sure you're buying the "R2.0" version, the second revision (ie R2.0) has pcie 5.0 to the pcie slot. the original version doesn't.
@VaporKnight if you wanted to, you can opt for 3 fans below, something like this:
(i wouldn't have the rear fan though.)
