Aircraft still in take off configuration so flaps 20 and gear down. MTOW needs 10,800 feet and the runway is 11,200 . it was also 40 degrees today in Ahmedabad so engine performance of the GNEX-1b would be down
But they got airborne and well over 500ft in altitude, so everything was fine for that part of flight.
RAT is very very noisyFew people saying they could hear the RAT which would imply loss of engines.
And you can hear this sound at the beginning of the crash video as the plane flies past the person filming.RAT is very very noisy
That often happens in a stall. Panic sets in and as the ground gets closer the instinct is to nose up.Very true, however a V1 engine failure could also put it in a similar place, i noticed the nose was way up as the aircraft dropped like a rock
Crashed on doctors/medical students? hospital accommodation it seems.![]()
Good advice in general really.I'd advise staying away from X
Just read 2 pilots views on pprune ; seems as above only 1/2 runway used
Live Flight Tracker - Real-Time Flight Tracker Map | Flightradar24
The world’s most popular flight tracker. Track planes in real-time on our flight tracker map and get up-to-date flight status & airport information.www.flightradar24.com
Some saying they retracted flaps instead of gear, but the controls for each are in vastrly different places. Add in an engine failure (last broadcast words indicated that), its a chain of events. Short take off roll, hot day, lose a donk on rotation or shortly after.
Based entirely on FR24 which may not have many data points, so not guaranteed they did an intersection departure like shown.Just read 2 pilots views on pprune ; seems as above only 1/2 runway used
