Apparently better than the AS6...Bridgestone Turanza 6 any good?
2025 Summer And All Season Combined Tyre Test - Tyre Reviews And Ratings
2025 Summer And All Season Combined Tyre Testwww.tyrereviews.com
no harm. they're not linglong ditchfindersI'm gonna give the Bridgestone a go, they are £10 cheaper for the pair which isn't all that, see how it goes.
Been using Pilot Sport 4's for ages, no complaints either, but apparently don't have them stocked at the moment, plus they are bloody expensive.
Kinda fancy a change anyway.
Yeah, your pic didn't upload...Any ideas what has happened here?![]()
Will try againYeah, your pic didn't upload...![]()
what everyone else said...something rubbing one out on the tyre inner sideNo way of knowing how this happened but we think something sliced open the inside of the tyre enough that eventually it just gave way.
on the plus side, no rim damage!![]()
did you manag to find out if anything was rubbing on the inners?Good. Don’t need a trip to A and E on top of the tyre problems.
conti sport contact 7 are the go-to nowadaysNeed new tyres for the Golf GTI, what's the best entry level sport tyres these days? Are Michelin Pilot sports still the go to?
My Money on a snapped springdid you manag to find out if anything was rubbing on the inners?
