Original thread
I decided that my pc was just a little too neat and easy to use… so why not just… go for it. A big whopper Watercooling build with hard tubing.
What could go wrong
It’s taken a galactic age to get all the bits I wanted together:
That’s not even everything as it excludes the coolant and a bulk buy of distilled water.
It cost an absolute ****ing fortune. There’s easily a grand of junk here, although I’m sure I could have shaved off a few hundred with cost-conscious purchases. The most obvious throwaway non-essentials are the hard tubing briefcase thing and the thermal grizzly mounting bits / kryosheet, but I quite fancied some ‘set and forget’ stuff.
The main bits:
Alphacool Apex CPU cooler (AM5)
Alphacool Core 5090 MSI Suprim / Gaming Trio GPU cooler
Alphacomputer Ultitube 150 Pro Reservoir with Leakshield + D5 Next Pump
2x 360 GTS black ice nemesis radiators
140 Alphacool rad
There is just so much bonus **** you need to get, it’s unbelievable, such as:
Heat gun
T - junction connectors
G4/G4 connectors that rotate
Drain valves
Stop taps
Coolant
Distilled water
Hoses and hose connections for flushing, testing and draining
Motherboard ‘jumper cable’
… I mean, damn…
Well, **** it, in for a penny, in for a pound
First job was flushing the radiators. This is what the mason jar and fish tank pump and stainless steel filter were for. I didn’t take any pics but it basically went from pump in the jar, via soft tubing to rad, then back to jar and into the steel filter. Worked pretty well and got gunk out.
I also checked that my pump was working:
Yup!
So far, so good… now… onto the tricky stuff.
Wish me luck!
What could go wrong
The main bits:
140 Alphacool rad
Heat gun
Drain valves
Stop taps
Coolant
Distilled water
… I mean, damn…
Yup!
Wish me luck!
