Am I best downloading drivers from the Gigabyte website theres a utility thereGame ready or studio?
I render 4k and game
No, Nvidia.Am I best downloading drivers from the Gigabyte website theres a utility there
Probably has a silent mode. Download MSI Afterburner if you want to set your own custom curve and have them running if that's something you'd like.Went nvidia.
Should the 5090 fans be running?![]()
imgur.com
Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.imgur.com
Where before but not since installing drivers
Read its normal on the 5090. They only spin when temperatures reach 50-65 degrees to reduce noise and power consumptionProbably has a silent mode. Download MSI Afterburner if you want to set your own custom curve and have them running if that's something you'd like.
Is normal on all modern cards, often called zero-rpm or fan stop.Read its normal on the 5090. They only spin when temperatures reach 50-65 degrees to reduce noise and power consumption
For FE peasants like myself - bust out the rarely touched thermal probes that came with mobo and taped them to the connectorNot a problem for me.
It is the reason I got an Asus Astral 5090 so I can monitor the power cable in GPU Tweak.
The connecter that goes into the gpu?For FE peasants like myself - bust out the rarely touched thermal probes that came with mobo and taped them to the connector![]()
Yeah this was the deciding factor for me too, i work in electronics and the honest truth is that i wouldn't be able to relax without knowing for certain, which reduced my decision making process to the Astral, or nothing.Not a problem for me.
Game ready mateGame ready or studio?
I take it the card came with Warranty in which case plug it in and use it , if it melts you take it out and send it in for RMA![]()
Apparently it works with all Asus cards not just Astral its not a shunt resistor it isn't going to balance the load but at least it warns youNo if it dies, it dies, but Astral the best for being able to monitor in real time any potential issues.
Or get a nice display case that can be hung on the wallI would play safe and not plug the card in. Yes you bought it for a purpose BUT think of all the hassle if something goes wrong. Best just look at it in the box just in case.
Take picture of it and frame it, and stare at it. Then return the 5090 for a refund. Win win!I would play safe and not plug the card in. Yes you bought it for a purpose BUT think of all the hassle if something goes wrong. Best just look at it in the box just in case.
It's only the Astral.Apparently it works with all Asus cards not just Astral its not a shunt resistor it isn't going to balance the load but at least it warns you
