A couple of weeks ago I came across
Vince's Repair Thread on here and was inspired by it.
Being a bit of a hoarder, I don't like throwing stuff away because I always think one day it or something in it may be useful.
So here's my Nintendo DS Lite with yellowing screens and pixel damager on the top screen near the logo.
I got in touch with a guy on eBay who sells used parts, I had a replacement charger off him last year so knew he was legit, he suggested that if the yellowing wasn't bothering me I could just buy a second hand bottom screen with yellowing so that it would match mine and a cable that converts the top bottom screen to a top screen.
So for £4.50 including free P&P he sent me this kit and a link to some instructions.
I stripped it down, used a set of carburettor cleaning brushes to clean all the holes and a toothbrush (new of course) to clean all the buttons and housing.
Half time.
Then I had to unsolder the speakers from the old screen, solder them onto the adaptor cable, then remove the metal frame from the old top screen and fit it on to the second hand bottom screen, then use a scalpel to remove a little bit of plastic next to the speaker, it was fiddly job especially as the adaptor cable required folding but I got there in the end.
All done.
Both screens now have slight yellowing around the edges but at least they don't look odd, plus with it being my first attempt I was reluctant to buy 2 new screens in case I messed it up.
Spent about an hour playing Asphalt GT to test it.
I know these consoles can be bought in working order for £10 / £15 / £20 depending on condition but I enjoyed giving it a new lease of life
