Yes, it appears so. I can see in home assistant that the heat pump generally uses about 1.4kWh per day for the hot water and 3.0kWh for the legionella cycle as often nothing else is running then. The Daikin MMI tends to just round this up to 2 or 4kWh. I think over a year it'll be pretty accurate when taking heating into account too but day to day and for low usage its useless.The Daikin MMI isn’t accurate at all is low usage times I find as it rounds the daily numbers by whole Kwhs.
I have an ESP32 to setup ESPAltherma, I just never got round to setting it all up again.
