I already have both of those![]()
I no longer play CDs, have not done for years, it's all been long ripped to local FLAC for the few music I have remaining in that format (60GB of). Everything else is on streaming services like Tidal and Spotify. Tidal I cancelled recently after trying it out and realising the mobile app is actually too buggy to be useful, and Spotify's algo is just outright better.
I also found that the quality of the mastered tracks matters more than streaming in lossless or playing local FLAC files, and Spotify seems to have an overwhelmingly large database of highly well mastered music from respective studios. The same went for using WASAPI-Exclusive (same as ASIO, just part of Windows instead of third party), just didn't end up being useful for the same reasons.
Which in turn is where my hifi playlist started to rapidly grow once I realised the above:
.Got my DX5 II set up now finally. Didn't get time yesterday. Straight out the box, without any settings changed music sounds so much more detailed and clear than my motherboard sound and hearing new stuff in songs I didn't pick up before. So far so good. The settings are a minefield to be honest. Anything I should be looking to experiment with in the menu? Don't mind doing a bit of research but thought I'd ask here before studying.
Also, I have a couple of speakers as well on my desk which have only a 3.5mm output, can I convert that to the 4.4mm connection on the front and connect them easily enough? They're not amazing speakers but perfectly fine for when I can't be bothered with my headphones (Amiron Home wired).
Perfect that'll work, thanks. Just checked the back and the aux cable is detachable.You can use an RCA to 3.5mm cable to convert if this is the sort of connection on the speakers to connect to the back of the DX5's RCA outputs, then flick between RCA out and headphones out depending on what you are listening to:
As for settings, 90% of the settings in the menus are preference and ease of use settings, the PEQ ones will change how it sounds if you mess about with topping Tune once they sort out the compatibility issues with the DX5 II.
seems decent! While was interested in the larger brother, the D9, it's a good sign the D7 reviewed well.Someone has finally reviewed the new audiolab dac, im trying very hard not to order it. Reviews the standard affair of audiophile fluff but very positive.
I'm gonna pass on the Audiolab as the Creek 4040 A taste is still in my mouth, the reviews praised that but missed all the issues I found right away
My DX5 II review went up too by the way for anyone interested, I think I covered all reasonable ground:
Topping DX5 II review - High spec headphones amp, DAC & pre-amplifier for under $300
Topping releases another device that produces high quality sound without the usual high price tag. The DX5 II covers a lot of ground, but does it hit that ground running, or does it face plant?www.neowin.net
Otherwise enjoy one of the funkiest pieces of kit we've seen in a while.Would like to listen to the Audiolab, one thing they do very well is DAC implementation, they make ESS chips sound amazing, people don't understand that having the latest DAC chip means nothing, it's 90% down to implementation which significantly impacts the final audio quality, I had the classic M-DAC back in the day which was a very influential DAC, so much circuitry surrounding a simple chip.
