I know it doesn't run directly from the house supply to the air con, and drains the battery first...my point was that I didn't expect the house to not be able to keep up with that drain and replenish the battery. I know air con is thirsty, it just surprised me that's all. Apparently not a problem with a proper wall charger though. Either way I guess it will still deplete the battery less than not being plugged in, so I'll keep doing it to maximise the range when I leave the house.On a PHEV everything like that runs off the DC HV battery, like an EV, so of course it drains that, then the AC hookup tries to charge the battery after a few percent is used. No car stuff can run off AC house supply.
The high draw for AC is just the initial though and it'll scale back and tick over at a low consumption rate generally.
Perhaps I should experiment and remote start the climate earlier...maybe tomorrow I'll check and see if that's enough time for the initial drain to slow as the cabin cools, and then the house replenish the battery fully before I get in.
