HUB aren't one of the sources I use. But I agree it's not a 1440 144fps card - the right hand legend could do with being recalibrated5060 is not a G tier its the one below, check the HUB review , cannot make 60fps , consistently at 1440 with DLSS let alone 4k
HUB aren't one of the sources I use. But I agree it's not a 1440 144fps card - the right hand legend could do with being recalibrated![]()
It's no more of a 1440p card than a 3070 is these days (as you'd expect from any 8Gb card).Given the news about Nvidia threatening GamersNexus regarding reviews, maybe a fresh look at who is used, especially for objectivity. The unbiased reviews that are out are showing its barely a 60 fps card at 1440p without DLSS upscaling
Question:
The 1440P 144fps claim is against tier G, but the forum recommends 5070/9070 (tier D) minimum for 1440p 144fps when discussing builds.
How do I reconcile the difference? (I'm planning a 1440p 144fps build soon).
Fixed and several other defunct shop links removed - thanks@Armageus Your link for the 5070Ti goes to the normal 5070 not the ti![]()
Not planning on including any Professional cards@Armageus will you be including the RTX 6000 when its released ? or not bothering as its not aimed at gamers particularly ?
My thoughts too. 5080 is closer to the 4080/4080 super (with the same vram amount too) than the 4090.Realistically not sure the 4090 and 5080 should be in the same class but otherwise a proper useful list, thanks!
