It usually shows up in the app within a day or two of the end of the day you want to look at.
That depends on your smart meter. Some support live reporting of export, some don’t. Mine doesn’t.Damn. Was hoping it would be live data or something with the Octopus mini.
With the mini it is live. You will see negative figure in the app when exporting. You have to use the live tab rather than daily tab to see it.
Only if your smart meter supports it.With the mini it is live. You will see negative figure in the app when exporting. You have to use the live tab rather than daily tab to see it.
My sister and her partner just got a new solar+ battery set up.
The pay back time on paper was actually a bit longer than expected.
How are you guys doing who've had installs for a couple of years doing?
Same here, my meter doesn't support live export power, currently exporting 5.7kW and the Mini shows 0. I just use the inverter grid power for live data.Only if your smart meter supports it.
I’m exporting 5.4kw right now but my min is reporting 0w. My half hourly reads show up 24 hours later.
Had my system installed Friday last week. 31 Aiko gen3 470w panels with two Tesla powerwall 3s and the gateway. The install went relatively smoothly apart from the fact they never cut the tiles to fit the brackets so they came back this week and redid the roof tiles cutting them to fit. Generated 91kw today and not used the grid since Friday apart from charging the wife's car at night. I've been watching it export nearly 10 KW to the grid every afternoon so waiting for my MCS cert now to setup my export with Octopus.
Was a bit more then that to install at £26k. The install is a bit more complicated than most though with the armoured cables runs to the garage and consumer unit. I knew that when purchasing though.Amazing!
If it was me running Octopus export department, I wouldn't hurry too much with the permission to export
91kw is massive, which direction are the panels facing?
How much did it cost? My guess is £21,600.
From my perspective, I was paying over £250 DD per month. I now pay £50-75 per month and am around £500 in credit. 3 years of ownership (thereabouts), 36 months x (250-75) = £6,300 in direct debit saving + £500 credit, that's nearly £7k. that DD includes gas too though. I paid around 11k I think at the time, so another 12-18 months all things being equal and I am basically quids in, and I don't worry so much about using electricity now thanks to also having a battery.
BTW did you check how they connected the panels to the Powerwalls?
Probably for maximum efficiency you want 6 strings with 5 or 6 panels each.
Many installers like to save cable and work and use fewer strings than optimal.
If you took a picture with the front cover removed, you can see how the DC string cables are connected - they are the in right upper corner, there are 6 connectors for 3 strings.
Are the Powerwalls installed next to each other?
I'm no expert, but IHMO you should move the 11 panel string to the 2nd Powerwall. It will put less load on the inverter in the 1st one - so it will last longer. And it will avoid two conversions, that loose energy - currently 1st Powerwall converts DC to AC, and the 2nd one AC to DC to charge the battery. Instead you can have the 11 panels feed DC directly to the battery. That may not matter much right now, if you don't have a heat pump - as you'll be selling all the generated energy to the grid, rather than charge the battery.
