RAM height is also something to look out for with the Arctic AIO's cos of the rad thickness.
how dose ram hight affect the rad? unless you have a very strange case
Strange case? RAM height is a factor in every case with a top mounted AIO - but more so with the Arctic AIOs because the radiator is so thick.how dose ram hight affect the rad? unless you have a very strange case
i dont understand that, unless your motherboard as no spacing from the top of the case
that got me thinking and i did have a problem with a AC F3 and a Phanteks XT pro, but the problem with the I/O shield and the 8pin'sprobably that yeah, I've read some phanteks cases have clearence issues.
You're using a pretty giant case, most ATX mid tower cases don't have that amount of space from the top of the motherboard. Your fans are essentially recessed into the top housing of the case right? Typical mid tower cases might have the rad in the top side but the fans would then be a little further down.
Here's the Arctic 240mm AIO in a Fractal case.
| GPU max length | 355 mm with front fan mounted / 300 mm with 360 mm front mounted radiator |
I have a very strange case, I posted this pic in another thread.how dose ram hight affect the rad? unless you have a very strange case
It may be that the 9070 XT takes a few seconds longer to show the BIOS screen - while the delay to boot has been set quite short (it defaults to one second on my ASUS X670E PG Lightning and I set it to three or four seconds to give me more time if I need to get in to the BIOS).Question for you guys.
Have just noticed i have no option screen to enter bios on first boot up, is this normal with a AMD GPU?
When i had the 3080 installed i always had the option to press delete to enter bios etc, now with the 9070 XT it is black screen until Windows loads.
Everything seems to work ok and i can enter bios if i mash the delete key during the black screen.![]()
I suddenly had something similar a while back with an nVidia GPU. The manufacturer's logo would show up, but there was no option to enter into BIOS. The solution was to download some kind of additional nvidia displayport drivers.Question for you guys.
yes because the drivers in bios and all thatI really am not joking. I lost access to the BIOS until I installed those additional drivers. I tried spamming the keys during the launch and it would not go into BIOS. I tried through the windows settings and the BIOS button was missing. Those displayport additional drivers/utility is what solved my issue. I do not know how it solved the issue, but it did. Do keep in mind I had normally working nVidia drivers and the nVidia app.![]()
My other pc with a 4090 and 7800X3D is gathering dust.
I don't get the option on my MSI B650 gaming plus WiFi since I got the 9070XTQuestion for you guys.
Had a look in bios and can't see any option for Boot Delay.It may be that the 9070 XT takes a few seconds longer to show the BIOS screen - while the delay to boot has been set quite short (it defaults to one second on my ASUS X670E PG Lightning and I set it to three or four seconds to give me more time if I need to get in to the BIOS).
Will try this later. (did not work for me)bit of a random fix or it was for me, i was cleaning my pc and had everything unplugged from the back and hit power button by mistake. after Shut down down and plugging everything back in it just worked fine.
Can't see any additional drivers.check if AMD has some kind of additional displayport drivers, besides the usual ones from Adrenalin.
