OK Folks,
I've bought this lot.
My basket at OcUK:
Put it together outside the case. So CPU & RAM are in Situ (No cooler in place) for bios flash as others here have said it will need it for 9000 CPU. Read elsewhere it would be OK to have CPU & RAM in situ for Bios flashback
Flashed to latest bios.
Didn't expect it to reboot after Bios flash, CPU was heating up so turned off b4 it overheats.
RAM lit up during Bios flash first time.
Turned it on again, RAM didn't light up.
Cleared CMOS, that didn't work.
Tried 1 stick in default slot 2, booted once, then didn't again.
Tried the other stick in the same slot - nope.
Tried both sticks In slot 4 - nope
Reflashed bios X 2 & cleared CMOS - nope
Reflashed with older Bios that supported 9000 CPU & Cleared CMOS - booted once then didn't again.
When it hasnt booted the CPU & RAM Debug leds are on - Checked for bent CPU pins - OK
PSU is my Superflower Ledex 550 Watter from my backup rig.
I thought I had screwed the cooler down too tight, its not been a problem when I've used it to cooler my previous rigs.
Could be any of the three that is causing this problem. Its off for now while I'm posting this.
Never had this problem before & I've been building my own rigs & for Family since 2003.
Anyone here suggest what I've done wrong or what you think what part has gone wrong?
Thanks.
My basket at OcUK:
- 1 x Corsair Vengeance RGB EXPO 32GB (2X16GB) DDR5 PC5-48000C30 6000MHz Dual Channel Kit - Black (CMH32GX5M2B6000Z30K) (SKU: MY-4DU-CS) = £119.99
 - 1 x MSI MAG B650 Tomahawk WIFI (Socket AM5) DDR5 ATX Motherboard (SKU: MB-375-MS) = £154.99
 - 1 x AMD Ryzen 5 9600X Six Core 5.40GHz (Socket AM5) Processor - Retail (SKU: PRO-AMD-02677) = £179.99
Total: £462.96 (includes delivery: £7.99)
Thanks.
				£150
				(incl. VAT)
		SAVE 3%
				£160
				(incl. VAT)
					£155
					(incl. VAT)
		SAVE 20%
				£249
				(incl. VAT)
					£200
					(incl. VAT)
  I didn't even know about the coin battery not being a thing anymore!
