What do you mean? ... You weren't able to download the ISO?
I thinking of trying something else.. Steam works great on nobara for me and Xbox pad if I wire it via USB, bi I just can't get the bluetooth to play nice with my Xbox pad and my Asus bt/wifi card. Wifi is fine though.
No, at the time, I was NOT getting the downlaod link, but yes, I did get it in the end.
Thenm whenever I tried to install it, I was just greeted with a blank screen after it tried to install.
For what its worth, I threw it into a VM last night, and I had a few niggles with it... I tried to install it onto a GTP but it kept failing to boot properly.
Then I tried a normal MBR and it still failed to boot???
And yes, I know how to install onto either, I have done it plenty of times.
I will re-try onto an actual PC later on, and I will try the old AMD A10 as that half decent and never gets used anymore, but AFAIK its got SuSE Tumbleweed on.
The same is true with OpenSUSE Tumbleweed. You can use btrfs snapshots and if one of the updates breaks your system you can just revert to the last working snapshot with one or two commands. Probably my favourite distro.Nobara has been a nightmare for me every time they do a distribution version upgrade, everything breaks for a period of time.
I’ve been using CachyOS which has been great, and as long as you use the right file system and bootloader (chosen at time of install) you get automatic snapshotting and easy rollback if anything does break. Which, on bleeding edge distros, they certainly can do.
His first Linux video trying Bazzite.
Have you had a chance to try Bazzite yet? Ive had Mint on my laptop for a couple of months now and it's been bang on for my needs which these days is just general media. I'm in the process of changing my devices from Windows right now and so far it's been fine with only a slight bit of an adjustment.I'm not saying I reccomend it, I plan on trying Bazzite at some point to see how that is, and I've used mint and ubuntu years ago, so i'll see how I go.
basically (when i can be bothered) I want to migrate from windows as my main OS to some sort of linux.
Are you still running Bazzite?I have today installed Bazzite on a spare PC I had as I’m getting fed up with Win11. Only an hour in but so far very much enjoying it.
11700k, RTX 4080 and it’s quite snappy.
