- 6 Jan 2013
- Rollergirl
I used this guide.I've still not found a way to do this for my lad yet![]()
They're both okay. Its slightly underpowered, but works well enough for them to be playable without any complaints. No worse than the switch version for sure.Do they both perform OK?
If I've read correctly Java is more power hungry, and bedrock is obviously emulating an android instance as well as the game.
Cheers
I haven't played it, but many reviews claim it runs well on the deck.Has anyone played Monster Hunter Rise on a Steam Deck OLED? How does it run?
Currently playing on. Switch One and the frame rate hurts my pc master race eyes
I had this working via the epic store, i did need proton 9-27-GTA.I have GTA V on my EPIC store which I managed to get onto the Steam Deck but for the life of me cannot get further than the rockstar launcher login![]()
Odd how many hoops done of us have to jump through to get it working. I remember only having to force a proton version to play it a year or two ago.I had this working via the epic store, i did need proton 9-27-GTA.
I also had to use a script to get it to launch as rockstar launcher would never login.
Was a bit of a pain and rockstar would log me out every now and then so I "found" another copy and its worked perfectly since using that one. Im about 70% through main story now with 0 issues.Reddit - The heart of the internet
www.reddit.com
Im not sure why but some people(me included) when the rock star launcher launches it forgets you have the game owned and prompts you to buy it. Without the rockstar launcher it was literally just a a proton version set and off we go,Odd how many hoops done of us have to jump through to get it working. I remember only having to force a proton version to play it a year or two ago.
www.reddit.com
I was doing it from memory sorry I used GE-Proton9-25-GTA although since then might be ok to use other versions proton is finicky with somethings.I wasn't using that proton so maybe that's why will reinstall it and give it a go, thanks![]()
Is that a new strain of COVID?Im currently playing through THPS3+4
So, it was Tony Hawk's fault for the pandemic ?Is that a new strain of COVID?![]()
Well it might be helpful to spell out what THPS3+4 actually is for those of us who didn't have a clueSo, it was Tony Hawk's fault for the pandemic ?
I've decided to get a second hand Steam deck OLED and have hopefully found one via a wanted thread. I'm initially going to setup emudeck and xbplay to dip my toes into things. I will then start to build out my steam games collection maybe starting with RDR2 as I've never played it, but hear it runs well and looks good. Aside from the items mentioned is there anything else people would recommend as essential things to get setup?
Can't wait!
