Weird new issue
20 Jun 2025
Drake Hotel, Chicago
EDIT: See the last post, I found the real issue!
So this occured a few times at the beginning of last week, and then hasn't happened since, then it occured on Thursday night once, and then last night twice...
The OS just randomly restarts the PC, when you're barely doing anything, it's happened when just sat on the forum, sat idle, but never when gaming?
Last night it did it after hours of use, then again within 10 minutes?
I haven't done anything to the PC other than recently tidy up the cable management... But I did check and nothing is loose?
Event Viewer has this to say:
Event 41, Kernel-Power
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly. (70368744177664)
Could my ram have gone bad? I tried to test it and it caused one of the restarts, usually it would halt on error after hours of loops. So I'm unsure if it is the ram in this case?
EDIT:
It's just done it again, this time whilst running Memtest64 on a loop with nothing else running, same Event Viewer error!
This occurs in both Windows and Linux, so it's not a software/OS issue.
Any ideas?
Thanks!
Have you tried reseating the RAM? Triple check power connectors at both ends as well (mobo and psu). If it is crashing when running the memory test that does suggest faulty RAM. Have you tried again with x1 DIMM or stock timings if using XMP or EXPO?
I haven't, but I will try that when I test 1 stick at a time with the Memtestx86 bootable USB - I'm just currently waiting 2 hours for Windows to 'Fix' my drive, I stupidly decided to do a chkdsk scan :cry:
This problem occurs in Linux as well, so it is definitely hardware related and not a problem with software/OS.
I'm going to disable XMP and try that next, when I got the ram I did do a 8, 12, 24 hour Memtest and it passed with both XMP profiles, so it would be strange if it's randomly decided to not like it anymore, but I agree it sounds like the ram, it usually is, but I've never seen a restart when testing it before, usually it halts on errors, when I've tested faultly sticks.
I have checked all power connectors 3 times haha, twice this morning and once last night :(
You might want to go back and check that all the lockable connections are tight and locked - at both ends.
Thanks, yeah I made sure. Will check again when I swap out my spare sticks of ram.
If it's going to be anything, I just want it to be the ram, if it has to be something :(
I've decided before I pull the existing ram to Memtest86 it with the xmp disabled by manually specifying the speed, I've seen that work before on ram that is higher than the supported speed, this way I will know if it's just XMP playing games, despite it working before fine when tested :confused:
My moneys on the ram has become faulty.
Opinions @Quartz @Firegod
do you use Memtest86+ the open source free program https://memtest.org
or the free or paid versions of memtest86 by PassMark https://www.memtest86.com
In the past I think it was the open source first option that found when I had errors before? But I have definitely used both.
I've just finished doing 4 passes with memtest86 by PassMark, and passed with XMP disabled and manually setting the MHz for the ram...
I'm going to do another 4 passes with XMP turned back on to see if I can get it to show any errors.
Which do you find is the more effective program?
memtest86+ is better as it has more tests. It's also completely free. last update was around 2022 which gives full support for ddr5 and will be updated again once ddr6 comes around.
Cheers mate, I was hoping that was the case, the paid for one looks a bit of a con, charging you just to unlock looped runs etc.
I'm pretty sure what I used in the past was the opensource free one :)
Memtest86+ all day long!
Bear in mind that if you're manually setting DRAM frequency and leaving the timings on auto, the mobo will set really lenient timings; they will be nowhere near as tight as the XMP profile. For a true baseline test, it would be better to load optimised defaults and perform stability testing that way.
However, since it's been working for a while, test with XMP enabled and reseat the DIMMs just to cover that off. Memtest86+ tests 7 and 8 (random, IIRC) are usually good at catching intermittent memory faults.
Can you post your full rig specs?
What's the PSU?
Corsair SF750 80+ Platinum.
It's just done 12 passes for 10 hours 14 minutes with Memtest86+ :) completely error free with manual DDR MHz set, so that's promising, I've set the MHz back to auto and enabled XMP profile 1 again, when I got this ram I did 8-12 hours on both profile 1 and 2, so I know it did work fine with no errors.
I have reseated the ram and unplugged and plugged in both sides of all the plugs, so we shall see how the next 10-12 hours of Memtest86+ testing goes :P
I'm hoping it's fixed now and somehow I must have knocked something when messing around in there redoing my cable management recently, but I did check it 3 times prior to redoing it again yesterday :P
Either way if it's fixed and I don't have to buy new ram or PSU, then I'm happy :cry:
I just hope real world it then behaves, as originally it didn't play up for days... Then for some reason it started doing it daily. Very strange.
Wish me luck :P
BIOS up to date? the current bios might not like your ram
Unfortunately it is, dude; however, it is a beta version due to when AMD had that scare with:
CVE-2024-36877 security issue, AGESA ComboAm4v2PI 1.2.0.Cc update - Added security issue of SMM Lock Bypass uCode fix aka“Sinkclose”.
They haven't updated it since the end of September :(
I was quick to update it at the time due to this, so it's strange that it would randomly play up now if it was buggy, although not impossible, I guess.
I did think that could potentially be an issue though, but there's nothing I can do on that front, until they bother, if at all, to update it :(
Currently it's passed 9 runs of Memtest86+ with XMP re-enabled :) so it might have just decided to play nice now if it is the BIOS being mischievous :P, or my 4th reshuffling of the cables, and ram modules, last night has fixed something :cry:
I shall leave it going till I'm home later and give it the full 9-12 hours, after that I think it's safe to say the RAM is probably fine?
Either way if it's now fixed and behaves, I'm a happy chappy :)
If you can run Memtest for 12 hours then I'd say the RAM is good.
TIme to let your usage of it be the next stability test, me thinks!
Yep, 12 hours has always been, a reasonable amount of time for me :)
Yeah, that's the part I'm a bit less excited about :P as it was some random when it would do it, then started occuring more frequently, there was no sense to it, and you couldn't make it do it on demand?
Hopefully it behaves now ;)
How's it looking now? OS still randomly shutting down while doing actual stuff?
Hello mate, I don't really want to jinx anything so I'll give it till the end of the week, as when it first did it, there was like a week apart, then another after it being on over 12 hours, then it became often and short up time before it did it, so I'll have to just keep using it and praying.
The silly thing is, it never had a problem if you were putting it under load gaming? It only occurred when idle or sat in a browser, so you can't really 'make it do it', as it were :confused:
Very odd. The PC seems to have a mind of its own :p
