I bought a RecovaPro (or something like that) about 5 years back too, but I've just found it wont charge. I might be able to get it fixed, but maybe not. How good is this one you've bought and how much was it? Would it be powerful enough for me to pummel my quads with?!I have a bigger massage gun i bought ~5 years ago which is fine, but by wife sometimes struggles with the weight. Figured this would be ideal, but i think i'll use it more too because it's a much smoother motion
That's pretty handy. Would be interested in long term thoughts. I've been drilling through some car seat runners which have been destroying drill bits, no matter what i buy or how slow i go
Cobalt with cutting oil, split point, and possibly 135deg cutting angle. Carbide likely to snap on you when used free-hand - ok in a drill press but not hand drill. Stubby drills might be better too if they're long enough as you're less likely to snap those.You need carbide or cobalt. Use some cutting oil too. Those things are usually hardened steel so need some proper hard bits, loads of muscle and some finesse.
Get out.That's very cool that it heats to 55c
I've never seen one of those before! Does the display contribute to temperature increase, or does it run quite cool?An new AIO..
£118 + del from ***elsewhere*** (OCUK don't sell them, so should be ok with the mention).
I can’t imagine it’d make any difference to the temperature as it’s held on by magnets and there’s a fair bit of plastic between the screen and pump.I've never seen one of those before! Does the display contribute to temperature increase, or does it run quite cool?
It’s idling as cool as a cucumber.
One good thing about being in NZ, is new phone release day comes earlier than anyone else![]()
