The AMD Driver Thread
Its none of these as before I put the 9070 in I had my 3060 Ti in there with minimal stuttering.. its an AMD thing that I had previously with Vega 56, RX 480/580, 7950 etc. I thought after 6 years of being on Nvidia that AMD would have this sorted by now but I was thinking brute force it with a 9070 lol It aint as bad as it was years ago but its still there, random stuttering/juddering.
Anyway I can live with it for now :)
I say this as I have a 9070 XT and I have zero stutter. I'm running a 13700k with 7400 DDR5. My previous 7900 XTX didn't have stutter either.
However when I changed from a 3070 to a 3090 when I had a 10900k with 4400 ddr4 ram it unveiled an issue with my RAM and I had stuttering and occasional crashes.
If you haven't got a frame limit set then your CPU and Ram will be working a lot harder due to the much higher frame rates, which may have uncovered an existing issue that wasn't noticeable at lower frame rates. Even with a frame limit set, it'll be working harder due to the higher minimum frames.
It's definitely worth checking.
Your VRAM wasn't the same on the 3060 Ti. So disregarding this seems weird. Is your VRAM running stock on the 9070 with these issues. Definitely worth doing a Vulkan Mem Test to see if the throughput is as expected for the data rate and that there are no errors detected.
Seems like I have almost sorted out the DayZ stuttering, I've just left all the settings at default for the DayZ game profile and use vsync in game. It seems better now I switched the refresh rates back to their native 144Hz from having them at 120Hz (reason for 120 is for streaming purposes having to have OBS at 60fps for Twitch). Tested it with Twitch by setting OBS to 72fps and it works perfectly. I guess the 3060 Ti didnt have the grunt to play DayZ and run OBS at the same time with OBS needing a fair bit of GPU usage these days.
The AMD H.264 encoder is decent now, pretty much nipping at the heals of Nvenc in my opinion. AV1 test at 25K bitrate with 1440p output to Youtube was just amazing! Typical that it all works great now I dont really stream anymore :cry:
There is one issue I noticed by accident and that is the glow sticks in DayZ were causing me stutter and fps drops while in the underground part of the Namalsk map (Athena 2). I never noticed it before so I feel it might just happen on AMD cards. I wonder what setting in the drivers could help reduce the fps drops?
Anyways I'm fairly happy now I know I dont need to use any of the fancy tech tricks built into the driver, just default and vsync in the game with native refresh rates is working very well, with game settings even to extreme if I need but then I might miss Famas Boy hiding in the trees so ambient occlusion is set to low :p
One more thing, minimising and maximising games from full screen is instant, I never had that on Nvidia, had to wait a second or 2, this was in Win 11 when I upgraded from Win 10. Also changing display settings is way quicker too, not needing to wait for all 4 displays to go off and on again. Oh and idle clocks running 4x 1080p 144Hz displays.. just perfect double figures with 30c-32c temps (even in this warm weather) which is just how I like it! :)
Try vsync off in game, with vsync on either globally or DayZ game profile in Adrenaline.
Could also limit your refresh rate slightly under your output refresh rate, might help.
Will try vsync in the driver, vsync off and the game just doesnt run smooth at all and I feel the framerate limit in the driver isnt that good and its a 'set for all', cant just limit to one specific game as far as I can see.
Riva tuner limits the refresh rate too, out of suggestions if that doesn't work.
Yea I used that for years and only just uninstalled it as I thought I wouldnt need it now with AMD :p If it gets worse I'll install it again.
Its only in this one place I get this issue but heres a screenshot of part of the underground section.
So Windows randomly updated my AMD driver today when it's not set to and Adrenalin now longer has a an update option.
Frickin MS. Don't think I'll bother reinstalling Adenalin, the switch to Bazzite may just have been moved forward.
Try windows update blocker it stops windows updating
/https://www.sordum.org/9470/windows-update-blocker-v1-8/
TLTW, really good, in some ways better than Nvidia... and he's now sticking with his 9070 XT, in effect AMD over Nvidia from someone very critical of AMD GPU's and Drivers in the past.
Never watched any of his videos before, thanks for sharing, some good comments there from someone that uses different parts of the software i.e. content creation. Some positive things for sure. Was a good watch. In fact @AMD_Vik he raises some thoughtful points on potential adrenaline improvements he'd like to see. Might be worth a watch and pass it on internally.
Still no driver update for FSR 4 in Cyberpunk.....
I'd be hopeful for a new driver next month. AMD do seem to release early each month. Let's see if I'm wrong next week. Lol. Given the Cyberpunk patch was released 2 weeks ago, with the note the driver was to follow at a later date, hopefully that later date is very soon.
Anyone else get pc freeze tho audio seems to work when alt and tabbing out of dune awakening when in fullscreen? Ive had it about 3 times now. Dunno if game needs a patch or its a gpu driver issue etc. Im on 25.5.1 driver atm, i know theres a slightly newer one but this drivers been ok up to now and didnt need the other one as didnt fix anything listed that needed fixing for me.
