- 6 Sep 2016
So you've not got a device pushing DTS into your G5? eg: A DVD/Bluray player?
Generally good to take TV picture mode from dynamic/vivid.
If he's got DTS sources then best to go source---->AVR---->TV. And only using E-ARC for the built in apps, then you will lose DTS but at least if BD is primary source you'll get all audio.
That's the problem with soundbars, not having HDMI in & out (say if they had built in HDMI switch) means you're stuck with ARC/E-ARC and then held hostage to audio codec support from TV. If brands drop DTS then you'll lose all DTS, from DVD all the way upto to DTS Master & DTS X.
